  • Replies 42
yeh i havent found it too be that bad! it seems smooth and stuff but i guess i havent driven with anything else before!! maybe once i get my car off DEFECTT i could let one of u take her for a spin to see what u think? but yeh she seems ok.
thanks for the replies fellas alot of suggestions, im going to go with getting a clutch myself from sliding performance, their prices are good. unless i can find the same one elsewhere.
5puk button clutch kit from SP
seems like a good price, 500 delivered, and plenty for the power I'm hoping to achieve.
Is there anything else I'll need to buy along with the clutch... i JUST changed my f**king oil (gbox) to redline lightweight and its beutiful stuff and i want to still use it as most likely itll still be blue when it comes out.
whats wrong wid you bitches....too scared to get your hands dirty? :P:O
do it yourself and spend the cash you save on a carton of piss to suck back while doin it.
its time consuming but f**k its only nuts and bolts.
button clutches arent that bad.
Edited by Ryanrb25
while your at it send your 5 speed to sims, and with the money you get buy a 30 pack of draught, then chuck a 25 auto in it and never worry about clutches again...
Just rear tyres due to those seamless first, second third 160km/h+ on the spot no brake burnouts. :unsure:
i got quoted 400 dollars for clutch fitment, machined flywheel, rear main seal replacement.
i wouldnt go there then it cost $400 to fit a clutch to my car yours should be about $250-$300 max
im booking mine into kent brake and clutch this week they fitted my last one and did a good job
if you want a quote ring tim on 8445 2055 after 8:30-4:30
The RB25 rear main seals are the same as a RB30. Cheap as chips. Also super easy to replace. A few bolts and its off, then slide on the new.
Machining of the flywheel, I can't remember what thats generally worth.
Either way $100 to machine a flywheel and replace a rear main seal, probably around the mark.
i said the above. did your cost of 250-300 include the rear main seal or the flywheel being machined?
so that means, 300 for cluctch and 100 for flywheel and rear main seal.
yes mine is fitment seal and machining
i went in today to get firm quote $450 fitting and $490 Xtreme HD clutch i just picked up then went and saw Brad Fox
remember pauly mine is AWD takes longer to do and is harder a little thats why i think yours should be alot cheaper than $400
is there anywhere in adelaide I can get a clutch for ~550 dollars and then fit it myself/ cheap fitment around.
Any help would be great, thanks.
I know its not of any help....
but I just bought a 2nd hand ORC Ogura Super Single with Cr Mo Flywheel from Terry @ Kansai Automotive for that $$amount :happy:
Top bloke that he is, even drove it down to Nisswreck (who are doing my replacement trans) himself.
Two thumbs up for Nisswreck and their service so far also.
More info please.
Wha happen?
Well, you see....
The noisey box was going to be replaced anyhows.... I was just putting it off for no good reason.
Driving on my way to lunch with Missa on Tues, clutch pedal started getting progressively sloppier and sloppier. Until, nothing at all. Just made it to Mel's work, pulled over and the clutch wouldnt disengage.
All of this = shagged clutch slave cylinder, which leaked all the clutch fluid along my route up fullarton road. I couldnt diengage the clutch once pulled over, nor could I get it out of gear.
can i get soemthing straigth here... my clutch is burnt out, it still driveable, but u need it hit boost for it to grip properly. all im looking at is a clutch replacement right? nothing else unusual is happenin with the car apart from a clutch odour.
Thats right just a simple clutch replacement.
Check out the slave cyl, and pivot ball while your under there.
If your after a slave/master cyl contact All clutch and brake listed in the workshop sticky. The blokes owned an R33 for the past 6years odd and knows what fits what.
For example... Slave cyl for mine was ~$38, master cyl was $75 new.
    • Hey guys I’m chasing a Rb20det complete or bare block need a good running engine as mine has low comp
    • You're making my point for me. 95 is not "premium". It is a "slightly higher octane" version of the basic 91 product. The premium product that they want people to buy (for all the venal corporate reasons of making more profit, and all the possibly specious reasons of it being a "better" fuel with nicer additive packages) is the 98 octane stuff. 95 is the classic middle child. No-one wants it. No-one cares about it. It is just there, occupying a space in the product hierarchy.
    • 98 and 95 have to meet the same national fuel standards beside the actual RON.  91 has lower standards (which are quite poor really), so 95 is certainly not 91 with some octane booster. It would be an easier argument to claim 98 is just 95 with some octane boosters. Also RON doesn't specify 'quality' in any sense, only the octane number.  Anything different retailers decide or not decide to add to their 95 or 98 is arbitrary and not defined by the RON figure.
    • Anyone know alternatives to powerplus tungsten? Can't find an alternative online.
    • 95 is just a scam outright. 98 is the real "premium" with all the best detergents and other additive packages, and at least historically, used to be more dense also. 95 is just 91 bargain basement shit with a little extra octane rating. Of course, there's 91 and there's 91 also. I always (back in the 90s early 2000s) refused to put fuel in from supermarket related fuel chains on the basis that it was nasty half arsed shit imported from Indonesia. Nowadays, I suspect that there is little difference between the nasty half-arsed shit brought in by the "bargain" chains and the nasty half-arsed shit brought in by the big brands, given that most of it is coming from the same SEAsian refineries. Anyway - if there's still anything to that logic, then it would apply to 95 also. 98 is only made in decent refineries and, as I said, is usually the "premium" fuel, both in terms of octane rating and "use this because it's good for your engine because it's got the unicorn jizz in it!".
