Yes it is my R33 GTR with 143.4 or 144 kw @ the wheels. I was very disappointed when I went home and checked againts my other sheets. Then a brain wave hit me AVO was done in 3rd gear..... 175kw 2 months ago......
I was on the dyno straight after you and I thought 'whoo hoo I should make more than the GTR, this will make my kw figure look more impressive' jokingly after we knew your GTR was obviouly not making what it should.
Then I had problems too and only made 137.4kw :D I was disappointed too. But hey there is always next time after all the problems are fixed. :)
What key ring?? :D
  • Replies 62
Members who have renewed this year are given a special SAU gift as a thanks for renewing.
It's an SAU VIC Member keyring / bottle opener.
Being in the wrong gear under "shootout mode" guidelines and correct dyno operation isn't mean to affect power output but every time I've seen a car dynoed in another gear the values are whacko, so dyno'ing in 3rd does skew the results unfortunately, which could explain why it was higher on AVO's dyno (makes sense now).
The standard limp mode could be triggered by a few things, one of the main sensors fried should do it.
Consult should tell you what sensor is toast. Look for the obvious ones, both AFM signals, water temp signal.
Well i found out today that RANK ROTARY dyno is Actually Out i showed Pete @ rank
the RE dyno sheet and he said:
"well that confirms it i had so many cars reading lower than what they should My dyno is out of wack by a bit"
So IM REAL HAPPY :) 238.8 rwkw and my engine needs a rebuild Thats Crazy power for the rb20. Once i rebuild should have way more MAYBE RB25 on the way!!!!!!
Anyway i never got a key ring are they only for brand new members?
i sighned up two months ago :) id love an SAU Key ring...
Oh well Who's Going to the Phillip Island Track Day next Week Cause im in
Fitted the Fire Extinguisher today
Cant wait oh yeah thanks for the photo of my car 2 Even though its like MULTI couloured
needs paint on all new parts ;) blue grill purple bonnet grey bumper...
when are you giving them out?
i should got one off ya at the GOR cruise....
Hey big thanks to CHrisman for introducing me to some great people and RCHOO and other members thanks for havin a chat to me as a new member i can really appreciate you guys helping out with recommendations etc...
A great turn out to a fantastic day! Was a very successful event I feel! Good work to the organizers and Ray and the guys at RE for doing such a good job.
Was super disappointed with my cars output but then again I knew the car wasn't right and hasn't felt it for a while, that's why I popped it on. Issues with AFR, Knock and Boost. Gotta stop putting off fix's so on that note, dropping the car a RPM tomorrow for some TLC. See you all at the next dyno day :D
I received them just before the Dyno Day. Your on a list to receive one as you have already renewed this year. Be patient, you will get one :D
Was super disappointed with my cars output but then again I knew the car wasn't right and hasn't felt it for a while, that's why I popped it on. Issues with AFR, Knock and Boost. Gotta stop putting off fix's so on that note, dropping the car a RPM tomorrow for some TLC. See you all at the next dyno day :laugh:
yeah and a boost controller that works maybe :rant:
I also had a good day....
My car went on near the end of the day when most people had left, was happy with my 140kW or so. Last dyno day I had 128kW, so the batmbl split dump and metal cat has added a bit.
I also was trying Boost 98 octane 10% ethanol fuel for my run. I know this has been debated before but i guess now we have evidence that YOU CANNOT RUN BOOST 98 FUEL in a lightly modded car if it is not SPECIFICALLY TUNED for the fuel. My AFRs where between 1 and 2 points too lean throughout the rev range. I'll post the dyno graphs up later.
But I do recommend that next time we keep a list of who is next on the dyno etc... I didn't mind staying around all day (til 5pm or so since 11.30am) to have my turn but I know that some people were getting a bit sick of waiting.
Cheers,
Rhett
Yeah Rhett i thought to myself on the day when you told be bout the 10% ethanol thing
that there's no way id run that in my car
i had a magna that almost died on that stuff
my afr were high too i showed my tuner and he said they were high but he said when he
tuned my car he made sure the were spot on so maybe that dyno afr's are out??? :whistling::P
he said he trusted his one cause he used a motec Top Of The Range Equipment???
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
