Im only able to go to .5 bar roubly 6.5 PSI
this is with the factory boost solenoid out of the equation, and my AVCR installed which i know works becuase i was running a bar of boost on my 180sx.
is there some kind of restriction with the wastegate, like a small tube or something that reduces the presure or something stupid liek that?
https://www.sau.com.au/forums/topic/161742-problems-with-boosting/
Hmmmmmmm the stock wastegate is ~0.6bar, did you replace all the piping when you hooked up the AVCR? Cause it sounds like you have the wastegate hooked up directly to your plenum, as I got the same result when I removed my ebc which was miss behaving and just hooked up my wastegate straight to the plenum, instant standard boost :P
i have it hooked up like this
Intercooler pipe, has the nipple on it
hose from there to the reference side of the EBC
THen the Com side is to the wastegate.
i dont understand it, i might be a bad solenoid now, but i dunno.
im gonna try and hook it up straight to the IC pipe
Easiest thing would be to have a read of the Jaycar IEBC thread. It has some good pics of how to set it up and references to the positioning of the flow restricting T piece(which the S2 doesnt have).
Plumbing the wastegate directly into the IC pipe will do exactly what Ska has said - the wastgate spring is set at 0.6 bar. The EBC needs to bleed off or restrict boost signal to the wastegate so the turbo is tricked into thinking that it hasnt reached 0.6 bar yet, so it keeps on increasing the boost.
I know it sounds obvious, but have you plugged the lines into the right nipples in the EBC. The factory instructions on mine were back to front, and I didnt find out until i blew through them with my mouth, while adjusting the regulator.
yes, i have it hooked up the same way my 180sx was, and it worked on there
ILl have a read on the thread you mentioned once i find it!!!
tanks
any chance in steering me in the right direction
only one i could find was of sydney kid building his hand unit
Yeah, that's the thread, You'll have to go to page two and three to see the pics. See the posts about the "free, 10 minutes to higher boost job" There is a lot of guff in there unrelated to what you want to know. But for me as a first timer it brought me up to speed on how the solenoids worked so I could figure it out from there. And on how the original plumbing worked. If there is any restrictor it will probably be in the T piece. ALternatively feel/squeeze along the length of the rubber lines to feel for a restrictor in the lines.
ok, since i conveniently keep all my vacume line in one place, i looked in the line that i took off the stock boost solenoid...adn low and behold there is a little restrictor in it
ill insert that in tomorrow and see what i can do
just becarefull not to overboost it
is it simply a matter of setting '0.8 bar' in the avcr?
i played with kylies greddy profec 2, and you dont set a boost pressure as such, more a boost pressure as a percentage increase over the stock boost, etc etc...
so maybe what ran 0.8bar on your 180sx is only pushing 0.65bar on your stagea? try upping it a bit and see what happens.
ps: a restrictor will increase the boost, as it drops the pressure, causing the wastegate to open later ie, instead of being 6psi at the pipework, and 6psi at the waste gate to open it, a restrictor can restrict 8psi at the pipework to only 6psi at the wastegate, thus it opening later and creating more boost.
  • 9 months later...
Hey yokotas13, a bit OT but im curious as to what mods are on your gloria and what sorta power you're making? My bro has a vq30det gloria and it would be interesting to see what we should do to it.
Cheers!
Edited by GorGasm
Isn't stock boost set to about 5psi? Whatever the wastegate actuator thingy is set to, you cant go lower than that...and stock boost is 5psi up until 4500rpm where it bleeds off some pressure to achieve ~7.5psi.
So it must be getting *something* just not working how it should.
I have a manual boost controller and I'm pretty sure it is ONLY plugged into the actuator and the top of the turbo, nothing else. The line from the IC pipe is plugged as far as I know. However this is a completely different type of controller and may have different setup requirements...
Maybe if people can post pics of their EBC setup?
    • You know what, I am enjoying your updates, but I have to say it is pretty poor form to walk into a shop that is paying for space and stock on the floor, try all their seats to work out what you are happy with, then buy somewhere else. If everyone did that the shop will be out of business with no opportunity for anyone to try a seat before buying. 👎
    • Good work, and thanks for posting up your solution for future people!
    • Yeah mate that’s the plan, I just want something I can have fun in and work on during weekends.  There’s really only 1 road fit to drive the car on and luckily is been redone recently.  I do want to tune it next year sometime, no dynos here so I’m looking at an ECU that can be remote tuned.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
