Hey Guys! Can anyone tell me where I could find the illuminated SKYLINE garnish that fits under the boot lid but between the taillights of the R33.
Not sure of which model this came about in, but my ol' boys N/A R33 has it and it looks trick! It glows an aqua-blue colour when the parkers are on.
I have seen a S1 GTR in a mag with this same garnish. Any help sourcing one would be great!
Thanks
L33igh.
https://www.sau.com.au/forums/topic/161779-illuminated-skyline/
  • Replies 166
Posted Images
Thanks Guys, having seen them in a range of colours i thought it may have been a DIY thing. Thanks again!
It is a DIY thing, especially if you dislike the aqua illumination from the factory option.
You will find my tutorial HERE
Any questions do not hesitate to ask.
I am assuming dan_the_man has a R33 facia; Yes it will fit both a S1 and S2. You may need to splice into the 12V wire as you loom may not have the factory plug.
Nah it should be fine, when I made one for my car and went to hook it up there was already a + and - sitting there with terminals ready for something to be hooked up, it even had its own fuse and factory nissan jap tags, (thats how I know its factory)
na that looks shit and i hate it
lol are you joking me??
mate that looks nuts you've done really well.
Would you mind reposting the circuit diagram, the images on the sau servers arent working :dry:
and btw what paint products did you use?
Cheers Mitch.
Edited by -R33GTS-
:dry:
Al, how much did it cost ya to get that sprayed? i remember reading in that other thread you gotit done professionaly. ive got mine prepped and stuff but i want it in the same paint thats on the rest of te car. not confident enough to do that myself
Would you mind reposting the circuit diagram, the images on the sau servers arent working :(
Cheers Mitch.
Glad it's not just my computer :(
    • All I can say Duncan is good luck and I hope that Neil did not run any E85 in Cheryl. I have recently experienced the full spectrum of fuel tank issues in my R33's that had been caused by E85 and contaminated fuel. When you take the cover off the top of the tank and have a look inside you will get an understanding of how easy it will be. Best case situation is clean fuel with minimal contamination. My GTR was like this and it was a very simple operation to just grab the fuel pump carrier bracket and slide it up and out of the tank. My three GTS_T's had different levels of fuel contamination that was probably caused by E85 in the fuel.  In the worst case all of the metal components in the tank had rusted to the point where there were pieces of rusted metal swirling around in the tank. This required the removal of the exhaust, the tailshaft, the complete rear cradle and the fuel tank. The components in the tank were that rusted that it took days to get the fuel pump carrier and the mounting brackets out of the tank. When the tank was finally cleaned, everything inside the tank had to be replaced. With the tank all back together I could then reinstall it in the car along with everything else that had to come out. Good luck and I hope that you find a clean tank.
    • It is a two door. It is black and also still has the OEM wheels and stereo. Exact model would be KR_R32RGFEL_SS According to GTR-Registry.com is a 2 Door Coupe; RB20DE; 2WD no HICAS; MT.F5; (11L) Projector Headlamps and Fog Lights; (12_) Electronic Active Full Auto Air Con (Climate Control); (13-14SS) V Selection -- Which seems to be accurate description of my variant. Will try to upload a few pictures soon. The OEM wheels look like the below image. Image is taken from the goo-net-exchange website.
    • Time: Saturday 18th January - 9am -10:30am Where:  Cafe By Lamanna 10 English St, Essendon Fields VIC 3041  - https://g.co/kgs/mhVKvAB Registration: So we can give the cafe a heads up on rough booking numbers please rsvp below Registration Link: https://forms.gle/wPtfj9Gp8bvCiouo8
    • Welcome Gabriel. At least your car has a glorious RB and not the shitty CA18. As MBS206 mentioned all the good bits can be added later. Two doors or four?
    • And half of them have been converted to turbos.
