Hey all.
As I am awaiting my garnish from an ebay seller $29 delivered ( not bad )
I was deciding on what i wanted to light up I.E. just under brakes or parker/brakes or reverse and decided that i wanted it to light up
under brakes and reverse so im heading out 2moro to get all the parts and hopefully my garnish arrives and with any luck my plan will work
but if it doesnt than its back to the drawing board ( and you guys will get free " dont do this or your break something advice ").
ill take heaps of pics of the curcuit board and put up a little tutorial on how to achieve a brake reverse system.
this should look really good.
1 question though..
My car is already black do you think this will suffice in stopping the light coming through or should I do a few coats of colour to be sure??
Just my 2 cents worth...
Cheers
  • Replies 166
Posted Images
I got one off mlt15e which he provided after a few weeks but the panel it was on was rough under the paint in certain parts which i consider quite an eye sore, especially if any light reflects or glares off the parts. That was the end of 2007. Since then its been broken promise after broken promise but for the most part he is just non responsive and refuses to refund. $350 or whatever it was wasted!!!
mlt15e is you read this come on man you seemed like a nice guy, do the right thing, replace it or refund. Ive never even hooked it up to the car and its been over 6 months!!!!!!!
  • 2 months later...
  • 1 year later...
well i finally recieved my series 1 garnish after the other one f'd up with the paint. made the circuitry about 3 years ago and is still not in my car.
it may sound like a stupid question but what is the paint called that is on your car, and will this paint stick to an acrylic base paint. As i was going to get a spray painter to do this, this time, as the other one wasn't the right colour. But as it is plastic you need a plastic adheaser right? then i was going to mask up the letters and paint it black (acrlyic) and leave it masked up ready for proper white spray QM1. Didn't want to give the masking job to them as it may stuff up cuz you really need a sharp stanley and bit of patience to cut around the letters.
Will this work? an info would be great as i did plan to have this on my car about 3 years ago and has still not happened.
    • Hi, We've all posted some thread, or know of some other person's thread, that contains information that we want to send people who are asking question to. But if we don't have a link readily available, have to go do a search for the thread before being able to do so. So, it occurred to me that we could possibly utilise the auto-text-replace function that fixes some of my swear words to perhaps auto replace some special keywords with text that also has a link to the thread. A specific example. The thread that I did with the improved R32 GTR wiring diagram scans. If the phrase "R32 GTR wiring diagram" could be auto replaced with "R32 GTR wiring diagram" then all I (or @Duncan, or any of the others that refer to the thread) need to do is remember that that's the keyword (or phrase in this case). OK, it would be better if this keyphrase wasn't that long, but it does need to be specific enough that it doesn't get triggered automatically. And obviously there are threads on turbo topics, or suspension topics that we could treat similarly. Alternatively (and/or additionally), I've been thinking about trying to build a library of the real expert content that is trapped in the bowels of the 25odd years of this site. Things like some of SydneyKid's content. There are threads that he started that should be more easily found, and he has individual posts, or series of posts, in other people's threads, containing very good information. Some of us know that it is there, but....just have no memory of exactly where/when/how we saw it. If we had some sort of library thread, we could put posts in there containing links to things we've found, suggestions for how to categorise it, then a mod or other appointed thread maintainer can copy the link and any key text up into the first post in the library thread. There are probably many other ways to get it done. Some sort of wiki is probably the best way.   Thoughts?
    • But, probably that happened to the last person too, which is why the RTV was there.....if you aren't putting a new gasket in you will need to seal the old gasket back to the metal surface with something, the gaskets will generally only work properly for a single use as they set/harden in that shape
    • What is with the horrible blue and white bit in the centre of the wheels, didn't that come off with some scrubbing?
    • Not sure how broadly you define Northside  but Castle Hill Exhaust are still around and could sort it.
    • I haven't done this as I still use the factory cluster, but I do know the circuits for the flash vs on for hi beam are separate which is likely the issue. The ON runs full power through the switch and the flash uses the relay in the engine bay. I'd hit the wiring diagram per GTSBoy's suggestion
