I had a blast yesterday apart from the weather, car issues and it being freezing.
It was a great day a big thanks to the Peter and Adam for getting it happening for us.
I started the day off really poorly with getting the car back together at 3 in the morning then it would start on the day, got it sorted and arrived a little late. The first few runs I had issues selecting gears and made as small pedal adjustment to give more clutch bite. Ran a few more times and laid down a few high 12's. Everything was running well so dialled in the N20. Ran a 12.337 then a 12.028 off a 6k launch with a 1.654 60 footer. I was pumped I retuned the nitrous jets for a 100 shot and was ready to run that 11. Thats when the bracket racing started and unfortunately the rain too so it was all over.
It was great to meet a few more SAU people and put faces to forum names etc, gotta get some of those ARC winglets Baron look cool.
Adam you should of told me about your car, I could have dropped my car off at home ( 15 minutes away) then picked up yours and taken you both home, I didnt even realise or know you had an issue with the driveshaft thats a real shame you were running very well.
  • Replies 156
I got a nice pic of you using nos in my pics check it out it is one of my fav of the day
Edited by nuttsHunglow
Congrats to Amy & Anna for great times for there first Drag day..
Im uploading some vids now..
I have one of
Anna vs Victor
Amy vs Stephen
Norman vs Charlie &
Norman vs Amy
Even tho it was horrible weather I think everyone had some great fun
Except for the people who blew things..
*hugs for them*
Thanks Corinne! Stoopid clutch, stoopid intercooler piping......lol
btw did anyone get a photo of the Sunny rim.. want to frame it for him.... that was nuts how that blew out!
Just got a video sms of my new clutch all working properly....... looks like it will be a good night on Wednesday!
- Anna vs Victor
Norman vs Amy
lol... I knew that was going to be the one the intercooler pipe flew off on :happy::)
Must thank the sunny for donating the clamps to keep teh bastard on for the rest of the day!
Can everyone who raced yesterday post up there quickest times.
The 300 community is wondering how well the 300 faired up against the skyline cousins
ZX2NV managed a
60 foot - 1.654
ET - 12.028
MPH - 114.12
KPH - 183.66 (3rd gear too)
Cheers
Jas
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
