hello all
i am looking at getting my rear spoiler removed so it can be repaired and repainted due to the clear coat having sunburn, and it is all falling off and generally looks like shit.
i have a quote to re-do the entire rear gate and spoiler as well as the eyelids i have at around 250-300 bucks.
painter also spottoed a run in the rear bar that he said would rub out no worries and then be cut up to look all brand new too.
so if i can get any tips on removing the spoiler without smashing/scratching any thing else around it?
also i would like to get the little plastic covers at the rear of the side windows removfed and painted black so it looks as if the windows go all the way back to the tailgate, so any tips on the removal of these would be greatly appreciated too.
cheers oxford
Not that I've removed the spoiler, I would say that first point to look at removing it would be to remove the inside plastic trim surrounding rear window. Easier to remove rear brake light cover and the trim will pop off quite easily.
More than likely there will be a couple of bolts holding in the spoiler you will need to undo.
Remove the two rubber grommets at each end of the tailgate - the ones where the electrics etc go through. And there will also be a mount in the middle once again, behind the oval shaped rubber grommet.
Dont know about the panels behind the rear glass, but removing the plastic inner lining would be the best place to start.
Has your car had a respray at some stage? I would doubt the original SFHC to be stuffed by now, and the run in the rear bar sounds a bit sus.
I'm about to do the same thing, getting a whole new kit fitted and want to reomove everything my self so I can sell it off while the cars at dmd. And the paint on my wing is stuffed too, all blistered while the rest of the car is fine. Strange!
Will try on the weekend but if you end up finding out let us know
I am inclined tobelieve the SHFC is a load of bullshit. My duco looks std but the bushes in mydriveway scratch the living shit out of my Stags paint job. Not to mention keys and worst of all, bloody diamond rings. (I've hocked mine to pay for the petrol) If you cant afford 98, buy a Dunnydoor and gas it. FLOLFLOLFLOL>
PS> I'm in a real good mood tonite caus I burnt the barbie pitch black and had to send out for Chinese.
And mybeloved SOUTHS are on a mini roll. WHOOOOOOOOOOOOOOOOOOOPPPPPPPEEEEEEE.
Shades of 68.
Edited by 66yostagea
i believe from what the yard i bought it from tells me anyway. my car has a small repair in the left rear quarter,and from what i can tell there is evidence supporting that but it doesn't look as though it was anything major, my painter has since told me that he sees the paint clearcoat peeling all the time on many imports whether they are nissan or other.
he also said that the SFHC is a load of shit too as it doesn't really achieve anything other than make the car harder to prepare if any repairs are req'd at any time in the future.
i have seen the mounting bolts on the side of the wing inside the rear gate but it appears that it is only a locator pin in the centre as i could not feel any thread on it so i a was wondering whether its held on with either urethane or double sided tape etc.?????
was also wondering what would look like without it too and just bog up the holes maybe? anyone seen one like that????
or buy a RICER wing for it and make it look like a daewoo hahahahaha
IMHO it would definitely have double sided tape as well as the mounts. Just use a long shape blade - it wont matter if you scratch the paint as you are repainting it anyways.
IMHO 2, keep the wing on, or why would everyone else be after Alex Cim to hurry up and finish off his group buy.
Josh does that mean your selling that front bar (in your avatar) and some side skirts?????
Everything will be up for sale (front bar, rear lip, side skirts, wing, R34 side mount IC, factory aribox with a k&n etc) I've already got the airbox up for sale in the Stagea section and will add to it as I remove other stuff. Next to go up will be the R34 side mount, hopefully after this weekend. But to be fair I already have some interest in some of the body parts but if that falls through then it will all be up for grabs.
Sorry back on topic now.
I think I'll just let the shop remove everything and then I'll sell it all after. Will be so much easier and the car won't look shite :unsure: unless someone finds an easy way to do it. Its not really going to make it cheaper for me.
Edited by Mr_RS4
super fine hard coat - not all stagea's have it, but if yours does it will be written on the rear window just above the rear wiper pivot :D
Mine does and I think its way cool - water beads off and over 100kph it just streaks off the bonnet even when its dirty.
my stag has sfhc but the panel and paint shop i took it to to get a ding fixed stufed up my bonet. they buffed and polished it and it left bad swirl marks after a few days. took it back and complained so the gave it another buff and a week later the swirls came back, moral of the story :) dont buff sfhc
On removing the side panels, the bottom part pulls out from the outside as it is held in by clips, the top half was very tight so I didn't wanna risk snappping it off. It's possible?? that the top clip is just a different type or mine just really tight. I would assume that the whole lot just unclips from outside.
Would proberly better to look it up on FAST 1st.
    • Would this not be the same for the exhaust you've posted up?  If your exhaust volume and emissions are fine, why does the brand of pipe matter?
    • The issue is more the fact that there is inspectors that deal with japanese cars a lot and they might know what a real Mines pipe looks like. And then they're gonna get antsy and not pass your car. But I'd have to talk to one of them about this, because you know as well as me that it's just a damn pipe and it effectively doesn't do anything. As I need to have my GT2860s and my exhaust setup (and the increase in HP) TÜV'd anyways maybe they can just correct the entry in the papers or assign a badge to the front pipe. I'm no expert either though, will inquire about this.     Thanks for the insight. Not sure if having a custom made pipe is good or not. Will find out in due time I suppose. Would be kind of funny if this was made in Germany though.
    • See this is a really tricky topic as technically the same rules apply to all cars but for cars but there is a difference. If you want to modify a car like the Skyline which never existed here you have a bit more freedom as they do not adhere to EU specs anyway. Any modification you do has to be in dividually checked anyway so as long as one of the inspectors think it's ok and within the TÜV ruleset you can get stuff like a top secret rear diffuser put in your papers. Which frankly would need a shitload of tests and certificates for EU spec cars, like a 2010 BMW M3 for example. But if you DO run these tests and all tests come out ok (safety stuff for the most part) there is no problem running such a part legally. It's just way too expensive to do for a single person on one car. The most touchy parts are emissions related mods, like an exhaust, turbos, air intakes. If it makes noise or alters the carbon emissions it's essentially illegal until you prove it's not. Meaning it doesn't exceed noise limits or have worse carbon emissions. I'd say for hoses if you replace them same same it doesn't matter what material they are or what brand you use. Same for nuts and bolts usually, they won't go and specifically check that your water hoses and some bolts are 100% OEM parts, that is nonsense.
    • What I don't understand here is that it mentions using a sealant. So either way you're ruining the inside of the tire and making a huge mess to clean up. Why not just do that, air it back up to spec, then take it all off and put it back in the car? Also, why not just include a plug kit that's not garbage?
    • What a f**king weener. I have worked in Gary, IN. At the time there were more gun deaths each night there than almost anywhere else in the world. Still not a reason to be afraid. 95% of people from your part of the world only have 3 teeth left from when you were addicted to meth, and now you're perpetually wrecked by Fentanyl. The only saving grace is that most of you didn't vote for Trumpler. Speaking of which, I'm off to the oval office right now. Got to relieve my bowels.
