Apexi Power Intake- Flutter!
johnabs
 Share
Hi,
Ive been hearing people saying that the Apexi Power Intake pod filter flutters and releases a wastegate type noise when u take ur leg off the throttle similar to a blow off valve. Is this true, as i currently have a K&N pod filter, and was wondering does the apexi flutter (eg. BOV or wategate pressure release).
Who has one, is it better performance wise or is it just all noise.
Cheers
John
wastegates do not make noises
there is no such thing was wastegate flutter
the noise you are likely hearing could be compressor surge, as a result of no or a very tight blow off valve
in no way what so ever will a pod filter make the flutter/venting noise. its all to do with the bov you have. all a pod kit does is eliminate the muffling effect that the stock box has and allows the sound made by your bov to resonate (echo). now some pods by different companies will affect the sound to varying degrees due to their differnt design, but they are all basically justa bit of shaped paper, foam or wiremesh on the end of a tube. just like the one you already have on your car
Since it's already been brought up, I've upgraded to a HKS 2535 but only on 10psi (for now)
I used to have the standard turno on 12psi and never had the flutter, just the load Pssshhhh,
Now with this turbo i get the flutter???? It's on the standard BOV. Only happens on full load between changes
Is the BOV reaching it's capacity?
I don't mind the noise but if it's gunna cause any damage, i'd like it sorted sooner than later.
Thanks guys.,.
Thanks guys.,.
I've just gotten my 2535 on too and have noticed something similar...only difference is that i have a rb20det and i'm using a standard gtr bov...any ideas people?
i had a very slight fluttering noise when i put my pod on when i back off the throttle gently but as soon as i installed my fround mount geez it flutters like crazy. it must be echoing off the intercooler pipes and gets heard through the pod im guessing?
for the guy with the 2535, you just need to adjust your bov, although your running the same boost, the 2535 will be feeding your motor cooler air, so there will physically be more air in the system, hence its fluttering now, same goes for you tek 01 with a front mount theres alot more air in there still when you back off, so thats why it will flutter now, just need to adjust your bov
what he said ^ let the spring tension out a bit so it can open easier/longer. as a basic rule, set it so it closes just before it gets to idle
the noise is always present and is amplified by the pod type, i dont run bovs at all and get crazy (dose, flutter and whateva) intake reverb noise on the rb26 and the SR20. BOV's can alter this noise but again have nothing to do with the cause.....only the effect
Edited by URAS
Well it seems like alot of ppl have the flutter with POD's etc. Well i have a front mount with CAI, pod and a stock BOV and i cant seem to get any flutter!!!! Any one tell me why not?????? (just a big woosh) HELP
 Share
    • Yes sir, that was me. Fake ARP's are also a thing over here in Canada and we only order from reputable dealers. It's sad that even simple things like bolts and hoses are now also being copied... anything to make a dollar.  Story time. Like all cheap crap from China, it's even an issue with firearms. Roughly 15 years ago, I purchased a new cheap Norinco 12g shotgun. First time out in the bush with it, while firing, bolt assembly didn't lock and it fired out of battery. The receiver also being cheap steel, basically exploded in my face. I was lucky to be wearing eye protection. Long story short, don't buy Chinese junk. Also Norinco being state run and their only military arms producer, if ever they do try and take over a country, don't worry about it lol.
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
