Hi,
Ive been hearing people saying that the Apexi Power Intake pod filter flutters and releases a wastegate type noise when u take ur leg off the throttle similar to a blow off valve. Is this true, as i currently have a K&N pod filter, and was wondering does the apexi flutter (eg. BOV or wategate pressure release).
Who has one, is it better performance wise or is it just all noise.
Cheers
John
https://www.sau.com.au/forums/topic/161823-apexi-power-intake-flutter/
in no way what so ever will a pod filter make the flutter/venting noise. its all to do with the bov you have. all a pod kit does is eliminate the muffling effect that the stock box has and allows the sound made by your bov to resonate (echo). now some pods by different companies will affect the sound to varying degrees due to their differnt design, but they are all basically justa bit of shaped paper, foam or wiremesh on the end of a tube. just like the one you already have on your car
Since it's already been brought up, I've upgraded to a HKS 2535 but only on 10psi (for now)
I used to have the standard turno on 12psi and never had the flutter, just the load Pssshhhh,
Now with this turbo i get the flutter???? It's on the standard BOV. Only happens on full load between changes
Is the BOV reaching it's capacity?
I don't mind the noise but if it's gunna cause any damage, i'd like it sorted sooner than later.
Thanks guys.,.
Thanks guys.,.
I've just gotten my 2535 on too and have noticed something similar...only difference is that i have a rb20det and i'm using a standard gtr bov...any ideas people?
i had a very slight fluttering noise when i put my pod on when i back off the throttle gently but as soon as i installed my fround mount geez it flutters like crazy. it must be echoing off the intercooler pipes and gets heard through the pod im guessing?
for the guy with the 2535, you just need to adjust your bov, although your running the same boost, the 2535 will be feeding your motor cooler air, so there will physically be more air in the system, hence its fluttering now, same goes for you tek 01 with a front mount theres alot more air in there still when you back off, so thats why it will flutter now, just need to adjust your bov
the noise is always present and is amplified by the pod type, i dont run bovs at all and get crazy (dose, flutter and whateva) intake reverb noise on the rb26 and the SR20. BOV's can alter this noise but again have nothing to do with the cause.....only the effect
Edited by URAS
Well it seems like alot of ppl have the flutter with POD's etc. Well i have a front mount with CAI, pod and a stock BOV and i cant seem to get any flutter!!!! Any one tell me why not?????? (just a big woosh) HELP
