heya cara,
i ran the extractor group buy. i knew a guy who was selling his extractors since he was selling his car, but i'm not sure if he's changed his mind...
try getting in contact with this guy: http://www.skylinesaustralia.com/forums/in...howtopic=159047
we got ours from a place over in new zealand. it's been a total nightmare for me to organize it, they aren't the best in terms of communication, and i was constantly on the phone trying to chase them up. i initially only ran one group buy, but everyone wanted a 2nd one most of them have received theirs.
we are waiting on two who opted for a slightly slower delivery method. if you really want i can PM you their web address and details, but i wouldnt be promoting their services freely after the headaches i had to deal with.
the alternative is to order a set of fujitsubo from japan, you are looking at $1600+ delivery.
another alternative is RB30 extractors (easily located within australia) and having the flanges cut off and modified to fit your exhaust ports.
cheers
eug
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005073
hey Eug,
how hard and how much headache is there with cutting the flanges off with the RB30? is it a fair amount of work that has to be done for it to fit my RB25? does it work out cheaper to do it that way?
Thanks
Cara
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005092
cara,
any exhaust shop can cut the flanges off. hell even i could do it with an angle grinder (bit dodgy though :unsure:).
a quick break down of what's involved:
firstly, you'd have to make sure that the port sizes are at least similar or the same.
then, cut off the flanges
get flanges made up and weld them onto the RB30 ones.
it's a pretty rough method, and price wise it'd definitely work out more than the prices i managed to organize for the group buy. although if you know someone with a mig and with a bit of skills, and could snap up a set of extractors cheaply then it'd work out similar.
hope that helps
eug
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005186
any good reputable exhaust shop would be able to do this no worries
the only thing that could cause a prob is the clearance around steering components, and the angle of attachment as the rb25 is a DOHC, whereas the rb30 is a SOHC (ie rb25 head is further out than rb30, if u get my drift)
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005856
cara,
with 4 (or more) buyers in our group buy the extractors cost AUD$185ea, plus a AUD$15ea gasket, and hp coating cost AUD$170 (optional) combine that with international delivery of approximately AUD$60-70.
you have yourself a set of basic extractors for as little as AUD$260 to a fully macked out set for AUD$430'ish.
$1200 is a rip off unless they plan on using titanium tuned length with gps system built in or something fancy.
eug
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3011358
    • Stock bypass valves are good for plenty of boost.
    • Check for fuel flow out of the outlet end of the rail. Check for spark. Try to start with aerostart (or pressure can brake cleaner or similar solvent in a car) prayed in through TB. If you have fuel and you have spark and it will fire on substitute fuel, then seriously suspect that E85 sitting for ages in your fuel system has destroyed something and put it in your injectors.
    • Nissan stock oil pressure is typically about 1 bar at 1000 rpm plus about 1 bar per thousand revs on top.
    • Luckily for safety applications, with dedicated links not being used for any other traffic, you simply run ProfiSafe (or an equivalent safety comms protocol from other vendors) over the top of ProfiNet (if that's what you're using, or Ethernet IP if you're stuck in the world of American PLCs and not verking vis ze Chermans) and the redundancy is more about being able to know that you need to cause a system diagnostic lockout because you've lost one of your comms channels, rather than not knowing that you've lost your only comms channel. Granted, heartbeats and all that are possible and useable and all that, but some safety applications are are so time critical that you might not be able to afford a few milliseconds until the next check.
    • M'kay....that's the one (single wire unit is just for dash temp gauge as you say) ; auxiliary air regulator is worth checking, and EFI relay of course.
