heya cara,
i ran the extractor group buy. i knew a guy who was selling his extractors since he was selling his car, but i'm not sure if he's changed his mind...
try getting in contact with this guy: http://www.skylinesaustralia.com/forums/in...howtopic=159047
we got ours from a place over in new zealand. it's been a total nightmare for me to organize it, they aren't the best in terms of communication, and i was constantly on the phone trying to chase them up. i initially only ran one group buy, but everyone wanted a 2nd one most of them have received theirs.
we are waiting on two who opted for a slightly slower delivery method. if you really want i can PM you their web address and details, but i wouldnt be promoting their services freely after the headaches i had to deal with.
the alternative is to order a set of fujitsubo from japan, you are looking at $1600+ delivery.
another alternative is RB30 extractors (easily located within australia) and having the flanges cut off and modified to fit your exhaust ports.
cheers
eug
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005073
hey Eug,
how hard and how much headache is there with cutting the flanges off with the RB30? is it a fair amount of work that has to be done for it to fit my RB25? does it work out cheaper to do it that way?
Thanks
Cara
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005092
cara,
any exhaust shop can cut the flanges off. hell even i could do it with an angle grinder (bit dodgy though :unsure:).
a quick break down of what's involved:
firstly, you'd have to make sure that the port sizes are at least similar or the same.
then, cut off the flanges
get flanges made up and weld them onto the RB30 ones.
it's a pretty rough method, and price wise it'd definitely work out more than the prices i managed to organize for the group buy. although if you know someone with a mig and with a bit of skills, and could snap up a set of extractors cheaply then it'd work out similar.
hope that helps
eug
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005186
any good reputable exhaust shop would be able to do this no worries
the only thing that could cause a prob is the clearance around steering components, and the angle of attachment as the rb25 is a DOHC, whereas the rb30 is a SOHC (ie rb25 head is further out than rb30, if u get my drift)
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3005856
cara,
with 4 (or more) buyers in our group buy the extractors cost AUD$185ea, plus a AUD$15ea gasket, and hp coating cost AUD$170 (optional) combine that with international delivery of approximately AUD$60-70.
you have yourself a set of basic extractors for as little as AUD$260 to a fully macked out set for AUD$430'ish.
$1200 is a rip off unless they plan on using titanium tuned length with gps system built in or something fancy.
eug
https://www.sau.com.au/forums/topic/161828-extractors/#findComment-3011358
    • I will check this as well, and get back to you.
    • IACV, (Intake Air Control Valve)?? Sorry, what is a BOV?  and I believe it is a stock ECU/MAF.  So, by removing it, just unplug it or take it out completely?
    • I just got to work and skimmed through 61508 and 61511. I was surprised the CSA adopted both, but neither are enforced. To recap what I read, it states that in a perfect world, they should be segregated but they acknowledge that this is not industry standard and clearly mention that they allow mixing of safety and non-safety. 61511 also mentions software segregation like AB does in their safety PLC's.   Now if only I could go back to control, let alone safety over comms. In my current line of work, we're only allowed monitoring and basic control over comms. Everything critical must still be hard wired as much as possible.
    • I've unfortunately never been as they're on the complete other side of the continent and another country that isn't currently letting us in as easily as they use to. I even heard their stop signs over there actually say "Stop" instead of "Arret". If I decided to trek the 48h drive, I wouldn't know when or where to stop haha. Whenever I order parts from UP Garage, I order from Japan as it's cheaper. Same with GKTech... oddly enough, it's cheaper shipped from Australia then it is the US.  UP Garage Japan operates their US leg though, unlike Tomei. If Tomei JPN had the power to close down Tomei USA, I'm sure it would be done in a day. They're two completely separate entities. Tomei JPN messed up somewhere originally agreeing to its creation and got sacked big time.
