i've verified that i have an oil pressure problem. the stock gauge has never worked so i installed an electrical AND a mechanical and both say i have very low oil pressure. cold start will sit on around 20psi. when warm it idles at 5 psi, and when driving on low or high rpm it will go to about 18-20psi, but never higher than 20psi.
it looks like either its a faulty pump or i've heard stories on the backing plat of the pump becoming loose and thus dropping oil pressure?
how comon is it for rb oil pumps to die? a few ppl have told me they had a problem with low pressure and it turned out to be the screws on the backing plate have come out a bit of have come out completely.
the car drives good, revs freely and makes good power (160rwkw) but on idle u can feel the motor jerking or bumping slightly. ive owned the car for 1 year and i believe its had low oil pressure the whole time. i wont be driving it much/hard till i get this sorted as i dont want to spin a bearing or blow any rings because of this.
any feedback guys?
https://www.sau.com.au/forums/topic/161849-low-oil-pressure-on-rb20det/
Generally when the pumps die the break and you get no oil pressure.
IF you are in luck it will be a simple backing plate that has came loose. Thats IF. :S
What did the last oil change look like? Any metal bits in the bottom of the drain pan after you poored the oil out of it?
As cubes said the backing plate could be loose or I have also heard of the relief valve getting stuck open and causing a similar problem. Either way sounds like you will need to pull the pump off and check it out....
oil changes are always smooth. just dark oil.
i have noticed however on first start of they day i can hear a "click".. but only once.
i hope its just the backing plate. what needs to be removed to check if the backing plate has come loose? just the sump or do i need to remove all the timing gear?
You'll need to:
Disconnect gearbox and any wires connecting to the motor (there's only a few)
Remove radiator
lift motor up
remove cam belt
remove cam belt drive gear using a small bearing puller
remove the sump
remove the oil pump and inspect
If all is well with the oil pump... You may as well continue to remove the motor and give it a freshen up or buy a second hand $600-$900 wrecker motor and drop it in.
A basic short motor rebuild is anywhere from 1.2-2k
dam thats not something im ready to do myself. taking it to a workshop then.
does it make any difference im using an oil filter sandwich plate? both electrical and mechanical gauges were hooked up to the sandwich plate as i left the stock sender+switch in.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
