GTR33 handbrake and Gear Boot $55..is this correct?
Really I was just wanting the Gear Boot...lol....but two for the price of 1
May as well change them both.
PM Me with banking details
  • Replies 518
Posted Images
i want in! are there any left? i sent PM but not sure if you received it due to the whole server maintenance thing going on recently.
Cheers
Ric
Edited by HEKT1K
  • 3 weeks later...
Hiya Bud,, just noticed you have left over Boots for R33 ,, I'll take it if the offer still stands., I gather they/re a un iversal fit for R33 & my GTS-T will be all good.
Just msg me the bank details & will transfer asap - i have commonwealth acct so if if ur's the same will go through straight away. Just pm me total cost inc shipping to 3012 (west footscray) Melbourne,
Cheers Darrin.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
    • I'm mark from Idaho.
