  • Replies 518
Posted Images
thanks guys, please leave postive trader feedback and I'll do the same :huh:
josh_s and rwjam2 I did a members search for your names so I can leave feedback for you guys as well but came with zero results?
received the boots today, thanks a bunch mate excellent and very fast delivery!
added comment under (vegie)
-kent
Edited by kent33
howdy, we also sell these but not for the price he is, they should only be selling for $45 because thats what we sell them for, and we can sell them at this price with no group buy needed,
Postage would be between $5 and $10 depending on where in aus you are, we are in SA
Guest
