Hey Everyone,
I am implementing a system similar to the HICAS system but on a formula SAE team race car, I was wondering if anyone could take a photo of the actuators for me and the whole system at the rear. I am trying to know whether or not i could use the actuators and motors from one of the skylines or 300zx to implement on the rear wheel steering.
Even better, if some one in the north eastern Adelaide area has one sitting around off of the car (since they often crap themselves) for me to look at breifly.
I am also still trying to see how it actually turns the rear wheels, any info or photos will help. i have been looking for photos for a while but cant find any decent ones on the net.
This is just the electrically controlled HICAS system i am interested in (not the hydraulic).
Not sure which skylines they were in but they were in the 300zx from 94 to 96.
Post any info on it as it may help other people that are having problem with their hicas system.
Cheers
Hey, that undercar pic i just found before reading this, must have missed that earlier. That helps a little. Cheers. We are encorporating 4ws (3 degrees on rear) on the car this year and are investigating the best way to get the car to turn and manuevour because our car sucked last year. I have been told to do it using electrically controlled solenoids, dc and/or brushless dc motors but have been struggling to find suitable (light) motors so far and thats why i am looking at the hicas system. (both for ideas and for parts) the main idea is to use the 4ws for tight corners where our speed would be less than 50km/hr because the tracks we race on have lots of them. (most tracks and roads skylines drive on dont so you may as well get rid of it.
Cars such as skylines are driven everyday mostly and these hicas systems dont last that long (ie less than ten years), and this car will be driven for a few hours each weekend and highly maintained plus I am hoping to do a better job at it then nissan engineers. (But they have produced some sweet cars!!!)
Thanks for the help so far but more would be awesome. (the hicas lock bar search just had replacement bars to get rid of hicas)
I still want to see inside of one of them units to see the gearing on the end of the main black motor.
also does anyone know how that motor is connected to the steering, im guessing just a spline but not sure.
Edited by slipperywhenboosting
Perhaps put a WTB post up in your relevant state. For an electric hicas system. Some people removes theirs entirely to save on weight. So they'd have them just sitting around somewhere. You might even get hold of one for free :( Then you can open it up and mod it all you want
You have a point there Dan, if anyone want to give me one to play with, i would be more than happy to pick it up in the adelaide metropolitan area. I am still wondering if it would be useful but i might be able to borrow one off of a contact at a japanese wreckers.
If I found out that it would be useful, i would buy one. Does anyone know how heavy this motor is?
If anyone reads this and has done something similar before, send me a PM, i would be very interested in speaking with you.
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
