  r32-25t said:
was there the best it did was a 13.9 (not a typo) from memory
Eeek - I would imagine the driver may have had some issues getting it off the line as the last time I saw it, the engine had a T88-38GK attached to a standard displacement RB26.
new gtr record in wa - 10.26 @ 197km/h
http://www.skylinesaustralia.com/forums/in...t=0&start=0
r32 gtr hks2.8stroker, motec, t88, etc etc etc
and he missed 5th approx 70m b4 the end
should be a 9sec street driven gtr
need i say more
btw, nice looking r33
Edited by 342Four
  NXTIME said:
Yes, 13.9@118?mph. Apparently, he just can't drive :( Probably doesn't want to break the Holinger in it. I'm pretty sure its not standard displacement RB26.
It was a stock RB26 which was supposed to be built - The previous owner blew it and the engine was rebuilt by Advan with JUN pistons and Trust rods apparently.
As for the holinger, I dont think it has one of them either :( Unless the owner has fitted it since he bought it from UAS
i know it has a built engine in it, just wasnt sure exactly what. And I know that it has a Holinger in it - I don't think the stock box can reach 140k's in first. :(
  Blitz said:
Yes, 'aftermarket' turbo :(
oh gawd... I cant drive and I got a 14.035 (w00t, I was trying to get 13.9 but didnt get time stupid rained out drag day) and im stock turbo..
hmmm :( Maybe he wasnt "trying" ? iono....
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
