Has anyone attempted to adjust their Series 2 electronic speedo ? mines about 10% out.
Is it adjusted through a trimpot in the instrument cluster or by changing the pinion gear in the sender ?
Why is it 10% out? Have you changed the tyre diameter?
D Cheers :P
  • 1 year later...
Just for prosperity's sake... my S2 is exactly 10% out too; reads 10km/h above what I'm doing (verified by GPS etc) at 60 and above. I have the standard tyre profile of 205/55/16 and brand new tyres. I'm going to fit the Jaycar speedo corrector kit - thanks for the verification that it works on S2 Chook! Which wire is it??? I would like to trace it without removing dash if at all possible...
i didnt have any trouble finding it, perhaps it is written on the back of the instrument cluster i think, and you can trace it to the plug and harness from there. If you still cant find it, send me a PM and ill pull cluster out and let you know.
Jaycar was bit confusing to set up, but havnt had to worry about it since, works great.
i think it is variable in 1% increments
Correct! Got mine today; two adjustments which can be used simultaneously, one varies by 1% per step, the other by 10% per step. I say 'varies' because it can be set to alter the speed UP or DOWN (ie. faster or slower). I agree with you Chook there are heaps of options...
I'll try to take some pics as I proceed. What I would like to do though, is install this in the passenger side kick panel, where I can splice it right into the correct wire near the ECU, rather than pull my dash apart and try to fit it in there. Can anybody think of any problems with this approach?
I have been looking at the pinouts of the R34 ECU (found here: R34 ECU pinouts) though and I can't seem to find a speedo output? Only "Vehicle speed sensor signal (Vehicle speed sensor 2) - pin 29" plus there is a "Output shaft rotation sensor signal (Vehicle speed sensor 1) - pin 58" however that is just for automatics (which mine is) and both those pins appear to be inputs, not the ECU output to the speedo?
Chook can you remember the colour code of the wire you had to interrupt to install your kit? I might be able to trace it at the back of the ECU and save some other people some dash-removing hassles...
Edited by DaveB
1 Problem: I think the speed sensor goes to dash first, then from dash to ecu, (or perhaps 2 independant wires) so either way, you would have to intercept before dash to change your speedo, at ECU will not change speedo.
Ill check dash wire soon
OK, 30min later, SPEED SIGNAL is BLACK with WHITE stripe, goes into the single row plug above the temp gauge on back of cluster. Just intercept it about 15cm back from cluster.
I checked some information about the V35/M35 speed signal and the signal is transmitted form the VDC/TCS/ABS control unit and received by the Combination meters and then re-transmitted by the Combination Meters (Dash Cluster) to the ECM (Engine Control) and the TCM (Transmission control) as well as the BCM (Body control). IF you were to correct the signal for the speedo you would have to do it before the speedo but who know how this will affect the operation of the ECM & TCM with a modified signal.
I dont know why the speed signal is out it doesnt make sense. Probably the easiest way to correct the signal is with larger diameter wheels (~3% greater diameter)
I can confirm the the M35 has the same problem.
Thanks Chook that's quick work! :laugh:
interesting... your m35 is a generation later (V35/M35) than S2 Stagea (R34), but I wonder how much they changed it for consult II etc? I notice on autos the transmission speed sensor appears to be on a different pin ("Output shaft rotation sensor signal (Vehicle speed sensor 1) - pin 58"); but your info does explain why I can't find a speedo output on the ECU; there apparently isn't one! damn. If only it were that easy...
Correcting with oversized tyres isn't always easy, and is expensive; could the rule of thumb that "if the speedo guage can understand the speedo signal and display correctly, the gearbox, ECM, BCM etc. must be able to" apply? I hope so... i don't like the idea of playing around with all those systems. I wonder what difference it might have if they were calibrated at the factory on the original spec' (10% high) speed sensor output? Although I'm hoping it's just a pretty basic signal that the kit will reproduce accurately. I mean I guess most cars that this kit is designed to be used with (ie. those with digital speedos) would have these other modern systems as well? There is a warning in the instructions about airbag precautions, so they must surely know *something* about it... I hope... ;)
OK guys done some further investigation of the wiring diagrams Mike posted up for the R34, and it appears as though the only time the signal is passed on (well, I have to treat the combination meter as a 'black box' and assume the signal is actually modified in some way by it) by the combination meter is to the TCM (Traction Control Module), however this is apparrently only present on rear-wheel-drive models.
I would hazard a guess that this signal could be modified with some degree of safety, since if you modify it for one circuit (the combination meters) you modify it for all circuits thereafter (assuming that it is a simple signal which the speedo correction unit is able to reproduce accurately, and that you have it setup properly, however the way to guage this should be to simply adjust things until the speedo is working as before).
This speedo correction kit specifically says 'handles AC output for Nissan cars', or something similar, which I thought was interesting.
So thanks Chook, I might have a hunt for that wire (black with white stripe) at the ECU...
DaveB
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
    • That's awesome, well done! Love all these older Datsun / Nissans so rare now
    • As I said, there's trade offs to jamming EVERYTHING in. Timing, resources etc, being the huge ones. Calling out the factory ECU has nothing to do with it, as it doesn't do any form of fancy boost control. It's all open loop boost control. You mention the Haltech Nexus, that's effectively two separate devices jammed into one box. What you quote about it, is proof for that. So now you've lost flexibility as a product too...   A product designed to do one thing really well, will always beat other products doing multiple things. Also, I wouldn't knock COTS stuff, you'd be surprised how many things are using it, that you're probably totally in love with As for the SpaceX comment that we're working directly with them, it's about the type of stuff we're doing. We're doing design work, and breaking world firsts. If you can't understand that I have real world hands on experience, including in very modern tech, and actually understand this stuff, then to avoid useless debates where you just won't accept fact and experience, from here on, it seems you'd be be happy I (and possibly anyone with knowledge really) not reply to your questions, or input, no matter how much help you could be given to help you, or let you learn. It seems you're happy reading your data sheets, factory service manuals, and only want people to reinforce your thoughts and points of view.
    • I don't really understand because clearly it's possible. The factory ECU is running on like a 4 MHz 16-bit processor. Modern GDI ECUs have like 200 MHz superscalar cores with floating point units too. The Haltech Nexus has two 240 MHz CPU cores. The Elite 2500 is a single 80 MHz core. Surely 20x the compute means adding some PID boost control logic isn't that complicated. I'm not saying clock speed is everything, but the requirements to add boost control to a port injection 6 cylinder ECU are really not that difficult. More I/O, more interrupt handlers, more working memory, etc isn't that crazy to figure out. SpaceX if anything shows just how far you can get arguably doing things the "wrong" way, ie x86 COTS running C++ on Linux. That is about as far away from the "correct" architecture as it gets for a real time system, but it works anyways.
