Hi All,
I recently took delivery of an HKS Extension kit (dump pipes) from Greenline. Upon inspection I noticed that one of the pipes has a large 4cmx2cm dent in it. I compared it to the other dump pipe which does not have a similar dent but is a slightly different design. I took it to Boostworx in SA where I have booked the car in to get the dumps + new HKS GTSS turbos fitted and asked them if the dent was designed like that. They said no. I wrote to Greenline and provided the following pics but received this response:
"Hi David,
Hope you are well. We have confirmed that the "dents" in the pipe are
normal and part of the design.
Please let us know if you require further information or assistance.
Kind regards,
Jason
Greenline Motorsports"
My question is: Is this dented dump pipe part of the HKS design or has it been damaged in some way?
**EDIT: BETTER IMAGES IN A POST BELOW **
Edited by writeoff
https://www.sau.com.au/forums/topic/161922-dented-hks-dump-pipe/
Man looks like they f**ked it by the rough marks around it and uneven finish
Unfortunately it's a crap photo. That's just the actual image not the pipe itself. The pipe itself is smooth and even, it just has a dent in it. I don't have a digital camera so my mate took those images. I might try and get some better images.
I don't know if it helps you, but I found a pic of my HKS dump pipes before I fitted them.
Click Here
I don't recall having the "dents" that you show, however from memory the pipe wall is bloody thick and I would think unlikely such dents could occur after leaving the HKS factory.
Does it look like the dents would aid access to any of the flange bolts? Just a thought that this may be some modification that has been deliberately specified to help with installation.
On an up side, I wouldn't worry about them as they will have bugger effect on final performance in y opinion. I would recommend that whilst you ceramic coat these along with your front pipes to help keep underbonnet temps down. Even better to do the terb exhaust housings as well if you have them off at the same time.
Edited by Gav
Hi All,
"Hi David,
Kind regards,
Jason
The dented pipe is the front pipe...it has the dent to clear the inlet pipe of the rear turbo...mine has a crease too, its just a bit neater than yours
Thanks Paul. It seems strange to have such a large dent as it does narrow the pipe considerably on the inside and I would have thought that would have an effect on the efficiency of the design.
I got my ones in from Nengun....They came in a box with manifold and Dump pipe gaskets.
They were branded HKS on them....There were no dints like the one you are showing me on them.
Did you get them in the box from HKS or did they just send them to you like that...in their own box?
And secondly do they have HKS markings on them?
Just curious...HKS Has a good reputation and QC....wonder if they have left one slip.
Please elaborate on these HKS markings you say your dump pipes have as I purchased a new set of HKS Dumps for my GTR years ago and they had no markings on them, and I have never seen any over the years that do.
same, got mine from Nengun around 8 weeks ago
nice and smooth, no dents
those dents dont look "factory" to me..more like damaged from delivery
Something has dropped on it to get that sort of dent.....
Maybe happened in production .
So writeoff........did you get them in a hks box or not?
And did you get all the other goodies illustrated in the photo below?
I have also got a second hand picture of a set off Ebay....no dents.
Well i always use the dent to go by when instaling "genuine" HKS dumps. not a great pick..but mine have a crease..not dint..and its always been there in HKS items.
EDIT. just looked at your latest pics...def. a production job...you can see from my pick the lack of clearance with the "bigger low-mounts. HKS pride themselves on being a bolt-on item, this dent is to achieve that.
do you realise how hard that pipe needs to be hit to dent it like that...bloody hard.
I do think dirt-garage has a point........The dent is meant to clear larger than life snails.
Write-off....if you are unhappy with it...return it or ask them to send you a photo of a few others to confirm some
can look a little more out of shape at that point than others.
The photo I have posted of this kit shows a definite mark at that point...bugger can't zome in.
Try to get a few more better shots for you....
Cheers
Tekin
They didn't come in an HKS box but I received an email before they were sent saying that Greenline repackage everything to avoid theft. The other items all came in a sealed package with HSK labeling.
The photo from ebay does look to have a dent or crease in it but not as pronounced as mine.
Good points raised there Paul. Thanks. Both you and Tekin have reassured me that I don't need to send this pipe back (thus costing me more and delaying me even further). I did send the more recent photos to Greenline and asked them to cc me with HKS's response. The email I received back said that HKS confirmed the pipe was designed like that via phone. :laugh:
Edited by writeoff
Cool...now you can "educate" Boostworx.
It worries me that they have never done a dump pipe upgrade on a GTR...I'd take it to Tillbrooks mate.
I was at Tillbrooks the other week while a prospective buyer had them check out my other GTR. I spoke with Mark and was impressed with the fact that they had 5 other GTRs in the workshop. The problem is that they are on the other side of town to me (thus a $80 taxi ride back or multiple buses that I haven't learnt yet - with 4 cars I don't catch the buses in Adelaide any more). I have also heard of so many people (1st hand) having bad experiences at Tillbrooks that I'm not inclined to go so far out of my way.
EDIT: 3 cars now. My Bentley was killed in January.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 馃槩
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
