check out JB 33 and myself on this link http://www.boostcruising.com orhttp://www.boostcruising.com/forums/index.php?showtopic=199612&skip=1 of us ripping it but in the archors mannor car park yesterday. my 4 door whore was being steered by 3 drivers as i like people to have fun. the run of my car on youtube is my girlfriend driving and there is a pic of me and the third driver.
JB in the black 33 also managed a 2nd place.
thanks for the guys on BC for posting this stuf up.
https://www.sau.com.au/forums/topic/161923-motorkhana-yesterday/
Sure it was your girlfriend driving Damo :D
The young bloke in the eski could steer, looks like it wasn't a bad turnout for it!!!
well they are heaps of fun but i warn people to get spare front and rear tyres as JB will tell you these tight layouts cop the outer edges of the tyres and usualy just one as they always turn one way. as well as the rears that fry up quickly.
i know i will be and JB might be but im planning on running in the state motorkhana series which runs all over the state in 3 rounds
first april 15 multi-club motorkhana wynyard airport
seccond july 15 multi-club motorkhana latrobe (this is held in the car park at the back of the speed way)
third august 26 multi-club motorkhana kellyfield
they are the three rounds dates and where they are. hope that helps. these truly are fun and are good skill learning events, and also cheap to enter.
yes that way my GF in my car on youtube. (note to every one elce, Dont let your partner beat you at your own game)
    • That's a good point. The rears of the covers themselves have no baffling at all though. Higher up more chance of air for venting the crank case. Lower on the side more likely to be submerged. I might be able to fit them on the sides but with both the sump drain fittings being on the drivers side the passenger one will need to make a U Turn and be nearer the turbo. But it will look neat being not up on top.
    • It won't likely matter where along the cam covers you put the big fittings. I would suggest putting them on the sides if you can, simply because it will reduce the flow up through the baffles and thus reduce the amount of oil that gets put into the foam. It might not matter, but it seems like something to consider as a worthwhile thing to avoid.
    • Well, I have my IM240 results with a cammed LS1... My Nox was 0.11 and my CO g/km was 0.2. Euro4 is 0.08 and 0.1 respectively. I'm gonna say for a stock RB this is actually plausible, BUT in Australia they were complied pre-Euro2, so the limits were: Which as you can see, is way higher. I'd say a stock RB with a new OEM Cat could? actually pass Euro4 for NOX but you'd probably have to do a hell of a lot of testing to prove it, and getting a car emissions tested and carrying a certificate of emissions when/if you get pulled over may be cost prohibitive if it's even allowable to get your car tested and re-classified. You'd have to find out what the UK Govt is using as reference material. It may be non-negotiable.
    • I made a little more progress last night and added some E85 safe fuel tank baffle foam in behind the stock cam cover baffle plate.  It still feels really wrong shoving foam inside the engine but apparently its fine based on it pretty much being the MINES/Hi-Octane RB26 cam baffle kit and the few posts here I have found of people doing it and the lack of posts saying the foam broke down and ruined the motor... Still plan to check it frequently though lol The last step for this round of oil control modifications I plan to make is to add some -12AN fittings to the cam covers and connect them to some (already existing luckily) -12AN fittings on the sump. Basically a sudo head drain/sump breather/pressure equaliser without having to remove the motor and do the one on the rear of the head. My plan is to add them to either the tops or the sides of the cam covers at the back. unless there is a compelling reason to have them at the front on the sides which i have seen a few times though they were all on RB26 cam covers from memory so that may be due to the stock breathers being on the back and the integral baffle being different ?
