hi, first time i'll be changing the oil in the new car (32gtr) and just wondering what these things like best? specially considering it's starting to get pretty cold here in canberra. also, are there any pointers about changing oil on these things or will it be as straight forward as my falcon? cheers guys.
ps, did search this but was surprised not to find anything.
https://www.sau.com.au/forums/topic/161928-best-oil-for-rb26/
personally I wouldn't use anything other than Motul Chrono 300V 10W40.
for some reason, my motor does not like it
the car had a ticking noise at the top of the engine on cold start when i used to use 300V 10W40.
then did a bit of reading, found out that full synthetic oil can drain from the head...thats why i switched back to 4100.
but my car is only a road car, with a very light tune on it.
cheers guys. advantages of the 10-60w? is it just better in the heat?
In theory yes, heat meaning full race conditions not just a 40degree day, but do you need to spend that much if you are not racing.
Most people agree you need a fully sensethic oil. The nissan manual refers to 15-35w oil. Oils have improved since the manual was made. The lower the first number "generally" means the quicker it lubricates the engine at start up (where most engine damage occurs in a daily driver). Lubrication = protection. Canberra gets real cold in winter, starting a car in sub 0 weather benefits from a lighter oil. For more details and debate on oils see the what oil should I use thread, lots of good reading.
5 litres $50 for my oil.
X 2 i got a r32 gtr, shredder667 u can get it from Autobarn in fyshwick if u get stuck give me a PM i live in Queanbeyan
X 3
Did all the oils for mine a couple of weeks ago...
motul 300v 10w40 for the engine
red line lighweight shockproof all round for gearbox/front and rear diffs
not enough redline High temp ATF for the transfer case so ended up getting some castrols in there at the moment.
bit costly but drives smoother than ever :)
jeff
I've lost two engines using motul 300v doing track days, after the last one i switched two Nulon 15w50 full syn and a dozen track days later still going fine ( over a period of five years )
which 300V and what else changed in that period of 5 years?
10w 40 and two engines, oilcooler on second, unless there's somthing inside this one i don't know about but it should be stock and been in place for 3 years.
The factory workshop manual recommends 7.5w 30 sg grade ( but thats for japans weather ), 4.2 liters without filter change and 4.6 with.
Edited by XKLABA
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
