10w 40 and two engines, oilcooler on second, unless there's somthing inside this one i don't know about but it should be stock and been in place for 3 years.
The factory workshop manual recommends 7.5w 30 sg grade ( but thats for japans weather ), 4.2 liters without filter change and 4.6 with.
Your engine failure wasnt due to the oil
Its due to a LACK of oil
Not sure could be alot of things but lack oil certainly not i have always made very sure the oil level was just over the full line ( about 3-4 mm ) before every time i went on to the track, both happened on very hot days ( 30 DEG and up ), one at Wakefield and one at Eastren creek and so i've stopped doing track days when its over 30 DEG and that seems to be working.
motul 300V is good enough for many factory race cars including nismo. it's good enough for me. franky, i'm not sure why your engine didn't 'like' it, but I'd say it's some problem with the engine, not with the oil. I have now been running it for 3 years. oil pressure at 80degreesC at 3000rpm is 6 bar.
If its all standard approx 4.5 Litres with filter of course, Enjoy your first journey of removing the oil filter from standard location :P its not fun :)
Its actually not as hard as everyone says it is :D. You just need to be standing in the right position (awkward) and get a backwards grip on the filter to pry it loose, then your home free.
I just hate the cleanup afterwards .... :)
Main reason I haven't got a remote setup is because I don't mind the little extra effort it takes on an RB26.
My oil = Mobil 1 10W30. For $85 for 5L it better be as good as the rest.
Yes many factory race teams probly do use motul oils but 300v we can buy of the self not likely,
6 bar 3000 rpm is to high when the recommended pressure at 6000rpm is only 451 kpa ( 4.51 bar, 65 psi ) as per workshop manual ( page 39 - en-22 ),
the first engine spun number 6 big end which i'd put do to tight off camber corner and the oil pick up drying out but the second one was all 6 and mains and to me thats oil failure,
which was not my point to start with, the point is stock or near stock GTR street driven buy any oil thats full syn and it should be just fine
6 bar at 3k rpm when warmed up sounds high. i only ever hit 6 bar when my engine is dead cold, when running it's 1-4bar depending on idling vs driving.
some people reckon that pressure is just a restriction of flow and that high pressure is a bad thing - means you should be using a lower viscosity oil.
i think having "some" extra pressure when stressing the engine is a good thing though. you want to make sure the oil is forced into the bearings and stuff.
Having used 3 types of oil since owning my GTR, including motul 4100 turbolight, motul 300v, and Neo platinum - all 10W40, i'd have to say the 300v came out on top. Pricy yes, but the car was alot smoother than either of the other 2.
Its only really pricy the first time you use it, because you need 2 bottles to put 6L into the motor (or so ive been told) so the next time you'll only need the 4L (1 bottle).
^^ that is lack of oil to a tee mate :)
yeah as i said, i have to find out what was wrong with it by giving it another go.
i know for a fact though it is one of the best products money can buy.
    • My take on gg2 48mm, 54mm, 58mm, and 62mm compressor map for same size compressor vs gg1 : All gg2 only outflow gg1 above 20 psi. As all g gen 2 surge line at lower left of comp map move to the right, all gg2 sacrifice spool vs same size gg1, surge line move to the right worst for 54mm gg2. So for same size compressor if you want best response, use gg1, if you want max hp at >20psi use gg2 but you will be laggier vs same size gg1. Max compressor efficiency drops to max 75% on all gg2 vs max 76%-80% of same size gg1. Iirc lower efficiency means hotter iat less dense air so lower hp at same operating point of comp map. Also curious why gg2 is mapped to lower max rpm vs same size gg1 (only 48mm size both gg1 gg2 mapped to same rpm) : 54mm gg1 165,000 rpm  vs  gg2 160,000 rpm. 58mm gg1 150,000 rpm vs gg2 140,000rpm. 62mm gg1 145,000 rpm vs gg2 140,000 rpm. If gg2 can safely spin to gg1 rpm then they can flow a bit more than as mapped. Good thing that all gg 2 interchange compressor and turbine housings with same size gg 1. So gg1 owners can buy gg2 chra only if planning to boost >20psi.
    • My stuff is all with Shannon's, granted, I don't really have imports I'm driving on the road, however, I've had multiple cars at the same time with them. Presently we have the Landcruiser on laid up cover, Sarah's Kluger on full cover, and the house insured. About 18 months ago Sarah wrote her Subaru Liberty GTB off, insured with Shannon's, and the payout, and buy back of the wreck was super quick. In 2020 we had the VF Commodore totalled in a major hailstorm. Storm was on the Saturday, I called on the Sunday and lodged it, vehicle was towed on Tuesday night, assessment team called on Wednesday to say it was a total loss and get payout details, money was in the bank on Thursday morning. Have had a few other claims both at fault, and not at fault, over the years, and never had an issue with them.   Funnily enough, they're also the cheapest insurer I find for things like Sarah's Kluger.   I will say I'm less impressed dealing with them lately around "the experience", as a lot of their staff that you deal with aren't car enthusiasts. Shannon's has a much more main stream feel ever since they decided to become "big corporate", laid a heap of staff off, and then hired a bunch of non enthusiasts. At the same time they've been making a push to be less "call us and we'll personally have someone who cares help" to "hey, this computer can do stuff for you" and are trying to get more square pegs to fit round holes. (That's just the vibe I get from them). Again, have had no issues with claims with them, but get a bit of a "less personal" feel from them.
    • A thing I wasn’t happy with with enthusiast was during the initial phone call they told me they’d insure it for 130k but needed photos.   I then sent them photos and they told me $80k as there were other cars either similar modifications available for around that price, I told them to send me the links to said cars so that I can buy them. i then sent the modification list with prices of the parts (no labor) and the price then came to 115k, which is still shy of the 130 that was agreed in the initial phone call
    • Ask me a bit later this week before payday
    • I agree that delayed payment probably isn't the most suitable solution. It seems a solid complete transaction would be best. As I wouldn't be using this sale as a line of credit that would typically earn interest, we can probably arrange a much cleaner single transaction deal. I can do $92.52 today. Would you prefer EFT, or Cash on Pickup?  😛
