**r32** Skyline 300 Km/h Speedometer Cluster Kits - $100 Delivered
Which colour would people prefer?
101 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
ok so you've seen the R33 white face 300 km/h speedometer kits.
I will be doing a kit for the R32s but only if there is enough interest. Please post a reply to this thread ONLY if you would buy one of these kits. also select which colour you would prefer the faces to be, white or stock black.
the kit also includes 5 blue or red LEDs for an extra $30.
  • Replies 60
unless you can also get to suit r32 gtr, i would prefer black so i can add it into my stock cluster
is there a difference between the R32 GTST and GTR clusters?
I want one for my R32 GTS-T
By the way, any pics mate?
Cheers
have a look in the R33 300 km/h speedometer kit thread. I have modelled these closely to the stock R33 gauges, the R32 gauges will be similar to stock as well.
Put me down for a BLACK kit for a R32 GTR. Do teh 5 leds do the whole dash? If so put me down for them aswell.
Josh
White with Blue LEDs
so far I am seeing that the R32 GTR will be the most popular choice. however it's still neck and neck between black and white face dials.
I would need about 30 definates before I can go ahead and get these kits made up.
So you won't be doing an R32 GTST version?
maybe I will do both GTR and GTST versions :D but will need a lot more interest than that expressed so far to even get this happening.
maybe I will do both GTR and GTST versions :) but will need a lot more interest than that expressed so far to even get this happening.
YEAH BUDDIE I WILL HAVE A WHITE R32 GTST...
Guest
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
