**r32** Skyline 300 Km/h Speedometer Cluster Kits - $100 Delivered
Which colour would people prefer?
101 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
I'll take black for a GTR aswel :D
cheers
(actually I'd still be interested if you could only do white aswel, but prefer the stock look)
Edited by Betz
  • Replies 60
I've added whether your car is a GTST or GTR to the poll. If they work out around even numbers then I will do both versions.
so would i be right in assuming that this is the complete cluster of guages and not just the dial face's..? that if i got it i would be takin my cluster out, directly bolting/plugging yours in and it would accurately read up to 300km? if so count me in with bells on... 32 gtst white face red led...
I know this is for R32, but if you can make them in black for R33, and they look as close to stock as possible, I will buy 1 straight away, as will 3 other members I know of :stupid:
i want a white 300kmh one for an R32 GTR!
when are these going to be available?
to make this possible I would need about 35 people to commit to 1 particular style. for example if 35 people could commit to a white face, R32 GTST model kit, then I would get that style made up.
I want white one for GTS-T
let me know when it available
Cheers
once I feel we have enough ppl for the most popular kit (according to the poll results) then I will go ahead and get them made up :P
ok looks like White GTST is the winner in this, and there seems to be enough interest so I will go ahead and get these made up and start collecting funds to get them made up :thumbsup:
Like Tofu said, I'm not fussed as to either white or black aslong as it's for GTST :)
I have started another thread to start collecting payments for White face R32 GTST 300 km/h speedometer kits. If you would like to reserve your kit then send me a PM. pics of the design will be posted soon :)
Hi Amec.
Wow! I was really hoping you would make these.
I would like a set in Black for an R32 gtst
dead keen on these.
Thanks
Should probably check out the R33 thread.. it's a face and then you solder something on the speedo to make it 300kmh :)
See....i would think not....considering the 32 speedo drive is cable and not electronic.
Explanation of how it will read 300????
If it really does read 300 ill gladly purchase.
White for gtr thanks.
Guest
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
