Nissan R33 Skyline 4WD 4door Manual *RARE*
Manual RB25DE
Up for sale is a 1994 Nissan Skyline R33 4wd Non-Turbo Skyline powered by a RB25DE.
Would make a very quick project car or a good p plater project that could be turbo'd once your off your p's
I recently got this from my cousin who has since moved overseas.
This is a rare find as not many people have come across a r33 4door 4wd in manual and even importers who ive spoken to have told me you only hear about these really and not many are on the road in this form.
The car has as follows:
Cold Air Intake w/pod
Aftermarket 17inch rims
2.5 to 2.25 exhaust with cannon
Just serviced it last friday with all new oils,coolant,platinum spark plugs
Feb 08 NSW Rego
CD Player
124XXXkms
Immac Interior, Kms show through the condition of the inside (dark grey, woodgrain around gear shifter)
Great exterior (gunmetal grey), slight chip on rear bumper, nothing too noticeable
4wd system very simular to the gtr models, when we had it up on the hoist on friday afternoon we found that some of the parts under the rear left tyre had R33 GTR markings on them, so this potentially could be a very quick skyline if you have the time and money to put into it
Im selling it because i dont have time to have this thing off the road to turbo it. Im running a business and to have this in a workshop takes up too much time.
For less than half the price of a r33 gtr this can be turned into a weapon if done correctly.
Being a 4 door is even better because insurance is much cheaper!
Ive attatched a few pics to give you an idea of it
Ive sourced out a rb25det motor ecu afm etc for about 1500 so if anyone wanted to have the contact, after buying the car i will give you those details so you can organise the motor which will bolt straight in and you can do the math... rb25det + decent amount of boost + 4wd = a quick r33
Asking Price: $10000.00 no offers
https://www.sau.com.au/forums/topic/161933-1994-nissan-skyline-r33/
all it needs is a RB26, great project car and hard to find.
Good Luck mate.
i know i wish i had the time and money to put into it! alot of people who ive spoken to tell me theyve heard of these but never seen one.
got quoted 6.5k for a full rb26 motor box etc for the conversion
1.5k for a rb25det which will bolt straight up to the box already in this
wanting to move onto something already turbo, with my business i barely have time to scratch my ass let alone worry about not having a car to get around with if this was off the road.
thnx :)
it's a good base for an engine transplant..
that's it..
that is why people are not interested.
The fact is, if you spent $10K on a good rb26dett transplant, it would fetch over $20K.
but as it stands, it is a 1500kg+ series 1 4 door skyline which would be bullied by a swift gti.
It's a rare car... It's a shame no-one sees the potential
Good luck.
that's it..
Good luck.
i was considering doing the rb26dett transplant but knowing my luck id be lucky to get 15k for it once done and then im losing more even!
thanks for the kind words, hopefully someone considers it to be their project soon.
    • Not R7R. Meant to type R&R, obviously enough.
    • Bugger "making it look stock". I put one conventional internally fused Hella relay behind each globe. I just pulled the plugs off the back of the globes and built new loom segments with male and female plug parts to match up to the original loom and the globe, and used the original power wires to each globe coming from the switch through the original loom plug to trigger the relays. Ran a big fat (also separately fused) power wire across the front of the car to feed all the relays. It's as ugly as f**k, but it is wedged down between the headlight and battery on the RHS and the airbox and headlight on the LHS, and no-one ever looks in my engine bay, and on the odd occasion that they do I simply give no f**ks for what they think. Fully reversible - not that you'd ever want to. For f**k's sake. It's a Skyline. They made million of the bloody things. We've been crashing them into roadside furniture for 30 years now. There is a negative side effect to putting relays on the headlights. The coil current is too little to properly clean the contacts in the switches and they get blacked up and you have to open them up every couple of years and clean them manually. I have 25 years of experience on this point.
    • I was poking through the R34 wiring diagrams vs R33 and noticed that the R34 has proper headlight relays while the R33 is like the R32 and sends full headlight power through the headlight switch. I'm not afraid of wiring but I really would like to do this in a way that looks OEM (clipping into open positions on the OEM relay box) and also unlike the factory wiring which interlocks the high beam and low beam on the halogen series 1 GTR headlights I want to make it such that turning on the high beams keeps the low beams on as well. Any advice on how to locate the specific connectors + crimp terminals + relays I need? I was thinking one NO relay for low beams and another for combined high + low running off the factory high beam headlight connector. I don't really want to splice into a crusty old probably discontinued factory harness so fully reversible is my goal here.
    • Pretty sure they run the same engine as the Q50 hybrid which specifies 95 RON.  I ran 98 in mine for a while, but it made no difference in performance or economy, so I have been using 95 for the last few years.  I have never hit 6.0L/100km, but have returned mid to high 6 on the highway.  Being a hybrid, fuel economy is a lot more dependant on how you drive it.  At 110km/h, mine never goes into EV mode on the highway, so returns closer to 7.5L/100. urban driving can return low 8s if you are careful or over 10 if you are a bit more enthusiastic on the throttle.
    • About a quarter of what you want to do. It's only R7R, not R&dismantle&replaceparts&reassemble&R. ? It is stock. I already told you, you will NOT have broken those. It's f**king 4th gear for Christ's sake. You just chipped the teeth off.
