hey guys and gals i am just wondering how much would it cost to get the front and back windsreens as i need to maybe get some since my windows are being taken out and there is a 90% change of em breaking so i am going to put some money aside for the windscreens. so what will a good price be as i dont want to be riped off and where abouts could i go to get em either bran new or second hand??
thanks
gordon
https://www.sau.com.au/forums/topic/161958-r32-windscreens/
I have a small stone chip in my windscreen thanks to someone at the Serpentine cruise.... I maybe need a new one if its starts to crack.
Do 32 windscreens fit GTR and gtst or are they diff'rent (strokes) ?
I got a big chunk out of my windscreen on the very same cruise! Let me know how much to replace the screen if you get it done.
https://www.sau.com.au/forums/topic/161958-r32-windscreens/#findComment-3012699
Get them second hand, my back window had an encounter with a brick, Nissan wanted about 1K for back windscreen - don't ask about the seals (I payed about $150 2nd hand - $250 seems to be closer to the average)
I got mine off a GTST wreck( I have a GTR, they are the same despite what Nissan may say), so it can be taken off without breaking, just take care and don't force it... take note of wether you or the donor have a wiper or not.
When your putting back in just get universal seals, don't look as good but price difference is ridiculous.
Edited by infamous_t
https://www.sau.com.au/forums/topic/161958-r32-windscreens/#findComment-3016888
Windscreens O/B do the front Screen minus antenna for 200 pesos, where as Nissan want your left Kidney. I just got a Geniric front screen for WOB for 200, and then I will replace with a genuine item down the road. I went with Nissan seals, cost 500 all up, front and back... Fit and finish just looks a little better than the universal items.
If you want genuine, call steve @ Northside Nissan
Mike
https://www.sau.com.au/forums/topic/161958-r32-windscreens/#findComment-3019362
  • 3 weeks later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
