Selling my GTR, Moving into real estate market. Not only that, I simply dont get the time to drive this amazing machine, so it should go to someone who can appreciate it.
List of mods:
HKS GT-SS Sports Turbines - Ball Bearing 320hp each
HKS Split Dump Pipes
HKS stage 2 cams and springs
Twin 3" Front Pipes into single 3.5" Exhaust. N1 Style Muffler
N1 Oil pump
N1 Water Pump
OS Giken Triple Plate Clutch R3C
Lightened Flywheel
Genuine Nissan N1 Block ($3,500)
GTR Crank (replaced)
Adjustable Cam Gears
Apexi Power FC 'Plug N Play'
Apexi Electronic Boost Controller Kit
Apexi FC Commander Hand Controller
Apexi Super Intake kit for 80mm AFM's
Apexi GT Spec Intercooler (no longer in production) 136mm Thick
R33 Gtst 80mm AFM's <Used
Greddy/Trust Oil Catch Can
Greddy/Trust Intercooler Piping Kit
CP Forged Pistons
Tomei Metal Head Gasket
NISMO Fuel Pump
600cc injectors
Apline MP3 Headunit w/remote
Alarm System with Remote Central Locking
Bride Reclining Racing Seats (possibly non-genuine?) w/genuine rails, nearly new
Nismo Duracon Gearknob
TEIN Super Street Coilovers (Adjusted for Australian Streets, Height and Dampening Adjustable)
Front Strut Brace
Michelin Pilot Preceda Tyres on stock GTR rims
Slotted Brake Rotors and Bendix Pads
Making 350hp at all 4, 1.2 bar. The car is still running on a base tune from engine build. Would easily net well over 300kw at all 4 with time on the dyno.
I have all receipts for work done, totalling well over $20,000. Most work including rebuild performed by Gavin Wood Autotech in queensland, within the last 24 months.
Please, no more 20k offers, any serious buyer can see the value in a car of this calibre.
Price is $24,000. Rego is due 15/06/07, will sell for $25,000 with 12 months NSW rego.
Contact via email is best - [email protected]
Thanks.
Edited by mitchy
https://www.sau.com.au/forums/topic/161963-silver-r32-gtr-modified/
Very nice car indeed...
How many kms on the chassis?
And how many kms on the rebuilt engine?
Whats stopping you finishing off the tuning and then telling us its full potiential?!?!
evo201 - Nice lancer, but not interested in swapping, as i dont drive this car as it is. Best of luck with the sale though mate.
ordinary - From memory, chassis has 128xxx km on it, these are genuine. Motor and all mods have done 20k or less. The reason I havent had it tuned and played with it a bit more is simple - I am at work sunup to sundown and beyond, almost 7 days a week.
I havent driven it in 5 weeks, let alone thought about tuning it. Besides, the thing is more powerful than i need, so I never found it an issue.
That said, figures are everything these days, so people should have little trouble seeing the potential in this setup.
Damn this is pretty much exactly what i want, at a good price.. Can't believe no ones bought it yet..
Can get a return flight to sydney for $150 so thats not too bad, what part of sydney do you live in?
Also can you send me some more pics (i'm trying to decide whether i like the colour) to [email protected]
Cheers
Edited by r32 gts-turbo
How's the rust situation, inside the rear guards, and forward rear cradle mounts, boot etc?
Also, will you consider selling the car a little cheaper if you de-register it?
How old is the clutch?
Did the crank go in stock, or is it fitted with an oil pump drive extension, or an R33 crank?
Last of all, what year is it?
I cannot locate any rust in the chassis at all.
Clutch put in at engine rebuild, less than 2 years ago, less than 20k on it.
Crank, I believe, is R33 crank.
Car is 1991 model.
Cheers mate,
Mitch
Edited by mitchy
  • 4 weeks later...
Another price drop, $24,000.
Cheers,
Mitch
Awesome job mate... :dry:
Any chance of an interior pic/s??
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
