G'day guys. I am in need of a pair of sideskirts for my R33 GTS-T. Am kinda open minded with style so just PM me or post here if you've got anything for sale. It would be better if they were in white, if not, well we'll see...
Pics are a must.
A thankyou.
Musky :D
Edited by Musky
https://www.sau.com.au/forums/topic/162002-wtb-aftermarket-side-skirts-for-r33/
  • 4 months later...
Im looking again for a pair of side skirts. Specifically more along the lines of do luck or trust side skirts. But let me know if you;ve got any others...
:D
