I must say that they both look very nice - but honestly; is there a point to it? Surely you're not 1) going to be staring at the glove box when you're on the track/strip and 2) not going to get the passenger to monitor vitals for you right :D
Il be running about 4 defi bf series in the glove box & split torque converter. i just want something sleek and hidden away. Not really into having 4 gauges across my dash.
shouldnt have to much of a problem with warning indication levels.
Edited by HKS99
Couple of suggestions :
1) counter sink the display and angle the guages towards you.
2) if they are the 60mm size guages, then the outside of a coke can is a good mold for guage cups if your gonna use fibreglass (used it in my dash to mount a boost guage into the plastic)
3) fabricate a locking mechanism for use on the track so it doesnt bounce around when its open
For the foam suggestion, i was thinking of velcroing the rear to the inside of the glovebox that way i can easily take it out without having to destroy the glovebox.
If i had a spare glovebox i would definatly fiberglass it however seems alot easier to use foam at this point
you can use foam as a base for a fibreglass insert cut to size with about 6mm of clearance total (3mm on each edge) then remove and cover in duct tape, then fibreglass over it, then you could mold in the guage cups etc how you need to angle the guages as required.
that first picture is the HKS one. I have that in my glove box and it is pretty handy. I have stored my HKS EVC, ETC, EDA and Defi control unit plus two 60mm gauges. It keeps things nice and tidy instead of velcro'ing or taping stuff to the dash and whats not. It is a bit annoying if you need to change settings though but i keep mine locked anyway so i cant change it while driving.
hey buddy, where did you buy it from? and how much was it??
or did you already buy it with it in your car??
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
