Removing Front And Rear Struts
MRO
 Share
I have just picked up a set of coil overs and need to hand over my standard struts (i think thats what you call them) in exchange. Are these hard to remove? I assume you undo the top 3 bolts in the engine bay and then there is a large bolt at the bottom.
I have never looked under the stag before so it will be a first for me tonight. I have changed springs in several other cars so doent think it should be a problem Has anyone else done this and how hard and how long did it take?
Hey mate its easy as ive done mine a few times now.
for the front end....
undo wheels and remove strut brace in engine bay by undoing the 3 bolts on strut tops as u said, then undo a single nut on the bottom of the coilover and slide the strut out :) dont forget to take the brake line off the strut before removal
rear end..
take wheels off and then take tops off strut tops in the cargo area and remove the 2 nuts on each side and then a single nut on bottom of strut and brake lines and it will come out :D
pretty basic, probably a 1/2 hour job to get all 4 out for your first go...
hope it helps mate
You will also most likely need a breaker bar to crack the nuts the first time they are removed.
A person will also be most likely required when installing the new struts to force the hub down for the coilover to fit in the allowed space.
You are right about the breaker bar! i cant move the bottom nuts on any of the struts.
I am meant to take the struts in tomorrow so i am desperately trying to loosen them. Any suggestions? How has everyone else done this in the shed at home?
WD40 and muscle torque. At the end of the day in those cases there's no special thing it's just concentrated force so make sure you're going the right way and heave into it!
get a longer breaker bar[put a extension pipe on it]
I have just changed the rear struts, it took longer to jack the car and remove the wheels than it did to replace the struts. I did have to use a hammer on the spanner to crack the lower bolts. All up it took about 1/2 - 3/4 of an hour to replace them.
R33 rear struts do not fit on the Stagea. The top mounts and springs are a bigger diameter than the Stagea.
After much searching, I ended up getting some 2nd hand after market Stagea rear struts, which seem to be an improvment over the originals.
 Share
    • Brand new r34 gtt box
    • What is the go to gearbox these days for a RWD RB? Back in the day VG TT boxes were cheap and strong. Seems they are as expensive as an RB25 box these days. What are the options without remortgaging the house?
    • Define "Nissan big brakes". You just mean standard R34 4 pots? And...it's not even the offset you need to worry about. It's really a detail of how much clearance there is between the caliper and the back of the spoke/face, which is affected more by the design of the spoke than it is by the offset. If you think about it....take any wheel, say a 19x8 that does fit and clears the caliper. Then add or subtract an inch of wheel on the outside, without changing anything else. You have changed the offset by half an inch, but not changed the clearance situation at all. Same for if you add or subtract an inch from the inside edge. The way for you to work this out is to take a wheel off the car, grab a straight edge and a ruler or two, and start to measure the distances from the wheel mounting face on the hub to the outer face of the caliper, and the outer diameter (that faces the barrel of the wheel) of the caliper. Armed with these dimensions and any other measurement that grabs your fancy while you are there, you can then go to the seller of the wheels and do the reverse measurements from the wheel's mounting face and see if there will be clearance to the caliper. There really should be. I have 17x8 RPF1s +35 clearing the caliper face by a finger tip. Those wheels do have pretty thin spokes with some curvature.... but then so do most wheels to suit Jap cars.
    • So I’ve got a r34 sedan that I managed to get green stickered, meaning I need to go through government approved wof station for my car to be allowed back on the road for some reason my car is certed for 19x8 rims.. I need these wheels  does anyone know what offset will be fine to clear Nissan big brakes? I saw 35et for sale near me, I can’t drive the car to test fit or risk being fined ..   I searched heaps online couldn’t find anywhere..
    • Okay, with all that being said about sloppy blowing from twins, I happily acknowledge the superiority of a single turbo setup on the RB; however, I still plan on double trouble.  I know the -9s were quite popular for some time because they seemed to meet that sweet spot between the -7s and 5s, would introducing VCAM and/or stroking to 2.8L provide the additional displacement/flow to push twins closer to the 500-600 goal?  Does it make more sense for a daily to just do an engine overhaul, slap some -7s on it and enjoy a bit more reliable power?  Has anyone driven a mine's overhauled and tuned engine?  I know they certainly don't approach the power numbers that you drag monsters do down under, but for daily street usage, I just want it to be fun and healthy.
