I'm looking at removing my AFR and Boost gauges from my pillar soon and flogging them off; one, it saves me a defect and two, my AVCR can do the boost, and I know my AFR's are right now.
I've been told that the AFR gauge is just wires, but the boost gauge has a tube going to somewhere on the engine. Does anyone know whereabouts this is? I'm looking at removing it ASAP, I need the (tiny amount of) cash.
Thanks for any help in advance guys, I'm still learning about all this. :)
https://www.sau.com.au/forums/topic/162089-question-re-gauges/
Mines not clear tubeing. Rather just plain black.
If the stock boost gauge on the dash is still working as well you are likely to have small plastic t-piece to allow for the connection of both hoses.
But yeah, its connected to the back of the plenum on the drivers side of the car on my R33 S2 GTST
    • I’m hosting a bunch of execs in the McLaren box on Saturday. If you’re around I’ll come say hi, and see if I can sneak out some freebies.
    • Yes. All of this. But even when you get the NOx as low as you can go on an RB, it will no doubt still be way too high. Same with CO and HCs. The tech and the tuning time just isn't there.
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
