quickest car i ever been in was a gtir. modded ofcourse.
similar to LTHLRB - a mate also owns one, did drive it hard and blew the box. been sitting in his garage for about 6 months now, not cheap to repair....
its one of those cars.....always loved em, but would never buy one.
they are not that weak. I ran mine with 180 odd 4wkw for a fair few years and I don't think anyone could suggest i didn't drive it hard. plenty of 7000rpm launches in it! BUT no flat changes, and a bit of mechanical sympathy is important. also short shifter is not a good idea, and the type of clutch you buy has an impact too. but i wouldn't say their boxes are fragile, it's just you need to be a little smart to keep them happy. apart from that they are good. they only weigh around 1200kg, can easily put out 2004wkw with standard turbo and injectors and at that power will dust off most mildly modded skylines. they do NEED a brake upgrade though as they come with shit brakes. top little car though, and a steal at current prices.
I owned one briefly.... but mine was a lemon..... previous owner dodged the maintenance records amongst other things.....
My mate had one also .... awesome car.. but it did have $40K spent on it at Rigolis!
In stock form I'd go the gtir over anything else in the same price bracket just because SR20 powah (and build quality) and the lack of money that needs spending to get it go faster..... although can be a b!tch to work on at times according to my dad (mechanic).....
GTIR drivetrain is a heap stronger than any wrx of the same year model.... our 97 wagon (clubspec) has done two gearboxes and the next time its straight cut gears! Also to me the wrx feels like its made of plastic.... but thats just personal opinion...
Fast little car,
If you ever buy one or import one, make sure it comes with exhaust already as its can be a bitch to fabricate a proper system. As for the clutch, if you need to change, get something that worth it as you would need to lift the engine up a bit and just chuck REDLINE shock proof in it and the box will be fine, offcourse don't abuse it too much.
What can i say about SR20, they are great 4cylinders, respond to mods as good as EVO if not better, engine and parts availability is much more as well. Oh also don't forget the quad throttles respond (was it quad throttles?).
Better interior than R32gtr :P, semi bucket seats, CUP HOLDERS ;).........
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
