Previously owned by Frink.
Im selling my R31 Series 3 1987 Silhouette.
Rego till 31/08/2007
Has: Extractors
Full 2 1/2inch exhaust?
Cold air intake and pod
New front and rear brake rotors and pads
Has a towbar too.
Stereo:
Head unit stolen recently, rest of car fine from break in.
Sony 10 stacker (needs headunit to control it)
Sony Explod speakers
Also comes with power inverter, cables for Sony PS2 wired in, cables wired in for a amplifier in the boot and an input/output box behind dash.
PM or call 0421780262
$1400 negotiable. Also selling starcorp wheels for extra $500 neg.
(comes with centre caps)
Will also come with 3 months rego!!!
Reason for selling: Datsun needs injectors asap.
Edited by datto260Z
https://www.sau.com.au/forums/topic/162141-fs-r31-series-3-1987-silhouette/
  • Replies 44
It has aircon, but not working atm. However, if it doesnt just require a re gas, i have a spare aircon pump to go with it. Its winter, so i couldnt justify getting it fixed till spring, then I decided to sell.
Conversions not too expensive anyway, i just had the 200 regassed and if it was old gas it was like an extra $100. So im not too bothered.
basically i need a tow car for my datsun when its built. So this would be good as a daily/tower if i get a tow pack on it.
I have to sell my 200 first though :D then i can join the skyline club el proper :(
Luke just told me it never worked for him :D
I forgot to put in that it has a tow bar, but im unsure of the tow rating. I have to get a loom for the lights, but i am getting that this weekend off a mate for free :(
What datto u getting?
I have a Stanza in my garage, its being prepped for hill climb/circuit, i have a forged L18 with custom flywheel and rebuilt SSS 5 speed, sparco harness custom mounted seat, the whole shebang. Just putting it all together still. Have been for the last 3 years :huh:
    • Just don't use ChatGPT or any other artificial stupidity for the equivalent of googling. Their demonstrated inability to discriminate reality from hallucination should be enough to make them totally untrusted. LLMs don't know anything and cannot think to even the smallest extent. They are just predictors of the next word, and that should never be confused with capability.
    • I think, given the usage model described in the OP, I'd never ever experience the wonders of the 400kW upgrade. What I really need is boost from 2000rpm and probably no more than 260-270rwkW. But I suspect that the highflow is not actually the turbo for that purpose, so I may in fact need to get a G25 or 30 or something right sized and very spooly. We shall see after it is tuned. I've had to back the boost and boost ramp off to stop the thing from pinging since the highflow went on, so I've been almost living the NA life for 9 months now! Injectors are recently in hand. AFM is in hand. Dyno is fixed. Just need to clear a queue of f**king Supras out of the way (and probably fit my new gearbox). So....some time this year? Lol.
    • For what I gather is a Sunday/summer car....braided is fine. You're not going to be left without a vehicle and you have plenty of time for inspection/maintenance. Oof. I wouldn't use them that way. They can probably handle the temperature** but the internal corrugations means that their flow characteristics are a bit shit. Lots of extra friction and pressure loss. Makes them flow like the next pipe size down. ** They are stainless, and the stainless can usually be at least something like 304L, which is pretty good at higher temperatures (unlike 316L, which I would use for a wrt/corrosive environment, but not a particularly hot environment). But the welding needs to be top notch. And even then, because you usually need at least one cone-seat end on them (because you can twist the hose and do up both ends at the same time unless one of them is a union) they can be prone to coming loose with heat cycles.
    • I don't have the OEM oil feed lines though and the turbo-wraparound line is torn, only has water. My plan is to get replacements for these and just connect a braided line to there. And make sure it's leak free. Hoses like these are also sometimes used to connect external wastegates, so for an EGR I think you're good using them.
    • Alright I understand. The most likely case is probably gonna be that I just keep the OEM unit in the car as long as it works.
