Previously owned by Frink.
Im selling my R31 Series 3 1987 Silhouette.
Rego till 31/08/2007
Has: Extractors
Full 2 1/2inch exhaust?
Cold air intake and pod
New front and rear brake rotors and pads
Has a towbar too.
Stereo:
Head unit stolen recently, rest of car fine from break in.
Sony 10 stacker (needs headunit to control it)
Sony Explod speakers
Also comes with power inverter, cables for Sony PS2 wired in, cables wired in for a amplifier in the boot and an input/output box behind dash.
PM or call 0421780262
$1400 negotiable. Also selling starcorp wheels for extra $500 neg.
(comes with centre caps)
Will also come with 3 months rego!!!
Reason for selling: Datsun needs injectors asap.
Edited by datto260Z
https://www.sau.com.au/forums/topic/162141-fs-r31-series-3-1987-silhouette/
  • Replies 44
It has aircon, but not working atm. However, if it doesnt just require a re gas, i have a spare aircon pump to go with it. Its winter, so i couldnt justify getting it fixed till spring, then I decided to sell.
Conversions not too expensive anyway, i just had the 200 regassed and if it was old gas it was like an extra $100. So im not too bothered.
basically i need a tow car for my datsun when its built. So this would be good as a daily/tower if i get a tow pack on it.
I have to sell my 200 first though :D then i can join the skyline club el proper :(
Luke just told me it never worked for him :D
I forgot to put in that it has a tow bar, but im unsure of the tow rating. I have to get a loom for the lights, but i am getting that this weekend off a mate for free :(
What datto u getting?
I have a Stanza in my garage, its being prepped for hill climb/circuit, i have a forged L18 with custom flywheel and rebuilt SSS 5 speed, sparco harness custom mounted seat, the whole shebang. Just putting it all together still. Have been for the last 3 years :huh:
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
