  • Replies 73
Eh nothing fancy .. Looks like a 3 series mazda .. Suppose would be alright if its 4wd and has a semi powerful boxter in it .. looks like a feather weight at about 7-8hundred kg .. would give a few cars a good run ...
come to think of it i object to the title to this thread. 'Just When You Thought Wrx's Couldn't Get Any Uglier' implies the current batch of WRX's are ugly as sin... i find them to be quite the opposite. They look tough as hell, if anything the new EVO is a bit on the nose
aaaaanyway :D
aaaaanyway ;)
Lets face it.....you have a point....WRX's do look great when money has been spent.
The title I believe was not knocking WRX's at the moment.....but was hinting to the fact that the next one will be F$%ked.
Its like saying....If you thought things couldn't get much worse........look at whats coming up... :rofl:
You are to anal....... :sorcerer:
Hey Guys,
first post, in defense of the new 2008 WRX :pirate:
Although all of us over at RexNet are not the biggest fans,
these pictures make it look a little better
taken from : http://www.caradvice.com.au/2014/2008-suba...eza-wrx-photos/
I don't mind it. Could be a lot worse.
I think that problem is that a lot of you are trying to compare it to the current model. If you have a look at it as a hatchback rocket, then it really doesn't look too bad. If it looked like a Daewoo Lanos, then you would have reason to complain.
first of all i have to say that i really hate wrx's, ANY OF THEM they are all nasty
okay so where do i begin.....
the front grill looks like its from a proton, the bonnet scoop doesnt match the car at all
the roof is too high, the back looks like a cheap lexus
the interior is disturbingly bland
jesus christ, i thought the new lancer was bad
LOL :):(:laugh:
Coming from someone who drives a N/A r33... slowest skylin ever made that is a bit harsh. I really think you need to wake up to yourself before you make silly comments like that, i have a lot of time/respect for skylines, but any wrx would be better then your car. The new WRX is definetly not something thats easy on the eye, but i dont think it will be that bad once everyone gets used to it/sees it in person.
Dayne
LOL :):(:laugh:
Dayne
Haha :laugh:
I think I am going to sell mine and either buy an Evo 10 or get an R34 GT-R at the end of this year, in which case I'd be spending a little more time on this forum :)
I think thats the problem... it *does* look like a Daewoo Lanos.
Hell it's like they're re-badged Kia Rios or some other shopping trolley like a 1999 Mazda 323 Astina hatch. I wish I had two more hands so I could give it... FOUR THUMBS DOOOOOOOWN :) I don't care whats under the hood
Its not hard to see that Subaru is copying BMW for body styling. The side of sedan wrx copys BMW 5 series, the hatch resembles 1 series.
They really have screwed it up this time (more shocking than the bug-eye version). rear of the hatch is hopeless although I can see some potentials in the sedan version in terms of looks. A new grille and a redesigned front bar from any tuner will fix the front end (headlights are not bad actually). no pictures of sedan's rear end?
Nice interior though. and im sure it will drive just fine.
that grey sedan one looks oooooookay, sort of, and why a chick test driver? Marketing it as a chicks car?
That blue one is ugly as sin, looks like a soccer mums car, id never buy one, i'll take my 17 year old GTR thanks...... and 0 - 100 in the 6 second bracket? Thats slow as!!!
Not. A. Fan. Man, I hope subaru takes note of what ppl r saying around the world...
http://www.smh.com.au/ffximage/2007/04/04/subMH_m.jpg
That also looks, well, better then that other ugly POS but still, rex's have gone to the dogs.
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
