I'm looking ahead into the future thinking about what I need to be getting first etc.
At the end of the day I'm planning on having the following mods on my car:
Full 3" exhaust
FMIC
Pod
Standard turbo
No boost controller (just whatever comes from having the exhaust)
Will I be safe going for the Apexi SAFC NEO?
Since they're pretty basic mods will adjusting the air:fuel ratios be enough to give me a safe tune with no knocking etc?
At what level of mods/boost/power does the timing go retarded? (I don't know much about this which is why I'm asking because I know the SAFC can't adjust timing at all)
Edited by so_tred
a safc IS a piggy back as far as i know,
maybe you're confusing piggy back with standalone?
i'm not extremely well informed on skylines yet but my guess is that you would be fine with a neo with those mods... especially if you're not going to touch the boost at all....
if you are not going to increase the boost then I don't see why you would need the larger intercooler when the standard side mount can more than handle the tiny increase in boost from the exhaust mod. Piggy back like the SAFC or SAFC2 should be enough to clean up the curve. Yes you will get people telling you to get a powerFC and that it is better yadi yadi ya...........but since you are only going to do the exhaust mods then it would just be overkill to have a powerfc.
But if you are going to doing more mods later on then yes.....go with the powerfc
Sorry, cleared it up a little. I meant piggyback as in the GReddy Emanage or something similar.
PowerFC is out for me anyway as it's an auto.
The FMIC is there because in the more distant future I probably will chase more power & get a bigger turbo etc..and let's face it, I like the look of them :P So I'm just doing it now instead of later.
Edited by so_tred
what he said ^^^^^
u should only see about 10psi max, in the coldest weather, with free flowing exhaust. so R&R wont be a prob.
cleaning up your AFR's will get you more power, and maybe better economy.
I use a unichip, they're cheap to pick up these days, they control afr's and timing. mine also has a boost controller module that uses the stock solenoid to control boost. very stealthy :P But you need to find soemone who tunes unichip. most tuners wont / dont tune them. Ive got a great place in sydney (C&V Performance), but that doesnt help you.
on the other hand, safc will do the basic afr's for you. anyone can tune those.
yeah everyone hates them. but then u find soemone thats been tuning them for years, and they get the best out of them.
but it seems irrelevant to this thread now since the thread starter has clarified a few things.
edit: but you cant tell me u'd go with an safc, over a unichip. that was my point, after reading the original topic question.
Edited by Munkyb0y
Be careful, SK has mentioned that some R34 GTTs hit R&R at 9psi.
After an exhaust, you should be fine, will probably get a tiny flat spot around 5000, but only a very tiny one. I did.
Also a FMIC will bring the boost a little higher as well, so by then you'd prob get R&R and a bigger flat spot. This is partly why I havent put on a FMIC.
Check around this other R34 GTT owners to see what their experiences have been. Let us know how you go. I've subscribed to this seeing as the findings in this also affect my mod plans.
I would say a SAFC would be fine enough for what we want, especially with the stockish level of boost.
Note: I dont think the car will be knocking much with an exhaust and FMIC, the standard ECU should provide protection against that by hitting R&R. I think what you want to do is get the most from the exhaust and FMIC without hitting R&R, and thats where the computer comes in. Chances are a badly tuned computer will be more likely to knock than one with the standard ECU only. (i might be wrong hahah)
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
