Autosports "ultimate Control" Skidpan No#2 Sat May 26th Oran Park
Bah!@Stockies.
I'll be out there on my good tyres, I didn't tear the last set up overly much at all especially from what everyone was saying. Although, I DID flat spot them from locking up. One thing I have to avoid this time... :)
Although Owen, you'll scrub on your guards, mine did the first time I was out, but now won't due to being raised!!! :domokun:
Haha you do remember how overley big Owens wheels are for his car.. they will stuff the car up for sure..
Owen, borrow a set of stockies..
  • Replies 88
Posted Images
there wont be much more benefit from having wider tyres as the track is half wet and dry.
if u have stockies it would prob be best to just use them and no need to worry...
The thing is the tyres arent just wide.. they are too big for the car.. silly people putting massive gtr wheels on gtst's :domokun:
And having one wheel sit an inch outside of the guard!
I know how big they are, they basically sat how mine used to. Just one of his tyres sits outside the guard for some frakked up reason...
Edit: Nismo: Twas only joking, was all part of the fun... :)
Edit2: I'll most likely be out with stockies on the rear too... Fronts will be good tyres.
J's car will have the other two of my "new" stockies...
Edited by MBS206
yeah i thought my car doesnt roll, and it doesnt lol. but when you spin, trust me it will roll. the photo of me spinning shows exactly that... the back is dead flat but front wheels have moved so much, i couldnt beleive it there must have been some nice twisting action lol
the track is not really wet, it just has a river through it the rest was dry. stock wheels are the go if you have some with rubber
um neither. its off the screen, below the sheds. you drive in past the sheds, turn right at scrutineering (you dont line up, just go paston their left) and head down past the hillclimb things
this has taken ages to come around....been looking forward to the day for ages now....fingers cross it wont be as hot as last time.....we all died in the heat and alot got sunburnt....
yeah your right its taking ages, but i bet despite sitting here like leyton hewitt (come on!!) i still wont be ready for it til the night before. all i gotta do is change the oil lol but you know.
yep droping oil this weekend, do a service it i think.....havent changed the spark plugs on a skyline yet.....anyone know the easiest way to get in their? havent tried yet, is the plastic cover hard to get off?
Also the plastic guards are under the oil filter, anyone know a trick way to change the oil filter withour droping oil onto the plastic? cant clean that up and will drop oil everywhere when i drive and on the driveway.
what sparkies should i get? can you just go to repco and ask for r33 skyline, cause its an import do they stock the parts?
Prob should have put this in the right section to get an answer...oh well too lazy....
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
