Autosports "ultimate Control" Skidpan No#2 Sat May 26th Oran Park
  • Replies 88
Posted Images
they are all piking it! i dont think anyone even took videos, the bums lol.
i might give the rwd turbo title a crack.. i could have easily been a lot faster than i was. esp in the final lol i stuffed up terribly
just had a new plenum to go in, spent 3-4 nights removing the stock one and doing a major service etc., made up some intercooler piping for it, then found that while it is for an rb25, i need a different air regulator (located under the stock plenum, attatched to the water rail) and also one of the threads for the aac was completely stripped so i couldn't have torqued it down on that gasket, i have to bore out the hole on the aac and then fit a larger bolt and retap the hole on the plenum to suit... too many things.
so i spent about 7-8hrs today in the rain putting everything back in just how it was, with new gaskets etc. all i have to show for about 15-20hrs work is a gtr thermostat housing and new coolant.
  • 3 weeks later...
I know its an old thread but I have been OS for the past few weeks so I missed much of the chat. When I got back a guy from the Autospot forum had sent me this:
It's some of my runs for the day and messing around on the skid pan. Most of the day I just had fun and threw the car around. On the last slalom of the day I took it a bot more seriously. Check out the handbrake turn at about 8:40 of the clip.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
