I was offered a bonnet vent on the weekend and initially I dismissed the idea out of hand, but I thought about it a bit more and it does make sense for a boosted car to get some of the excess heat out. Has anyone here done it and what sort of vent did you use?
I don't think I will use the one I was offered (butt ugly) but if I did do it, where abouts would be the best place to put it?
Also, if anyone has any photo's of the underside of a bonnet with the noise blanket removed I would love to see them.
https://www.sau.com.au/forums/topic/162182-bonnet-venting/
yep carbon fibre FTW!
unfortunately there is no way the finances will stretch that far, besides, with my cars complete lack of aero, including the std front lip, I think it would look plain silly. I am really chasing function over form here, but at the same time I dont want it to look like I was a honda owner in a previous life :dry:
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3011942
you dont need your car for us to know that. he he.
umm you could just find a simple vent. then get a panel beater to mould it into the bonnet. not hard for someone with knowhow.
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3011963
*biatch slaps the pommy car driver*
I was actually a card carrying certified trevmobile driver....
still got half a wardrobe full of Ford apparell.
I know this won't be hard, but I want to figure out the best place to put it with out having to cut through braces etc.
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3011999
well my fav bonnet for the stag is the one made by Masa, and Masa also state that the cars engine temps drop by 10deg using their bonnet, pitty its like over a grand shipped to my door and unfortunately i have way more important things to buy before a bonnet
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3013050
I know my carbon fibre bonnet on my 32 makes a world of difference to the temp it runs at, especially on a warm day with the air con on!
You could go drift spec and put spacers on the back edge of the bonnet to raise it slightly to allow some more airflow! Would be more legal too, cos i know the po po arent a fan of my bonnet! :rofl:
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3015368
Hrm, completely stock wagon with NO aero at all, with a drift spec raised bonnet rear....
Nah that wouldn't look wanky AT ALL! I might go and get some "V-Tec Yo" stickers when I pick up the spacers...:rofl:
Picsorban
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3015550
very very noice! :happy:
the police hassle you about that bonnet? I would have thought they would pay more attention to the wing, but...*shrug*
I was more thinking about just putting in something along the lines of the 2 vents on either side.
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3016049
dont forget you can get those vents that sorta dip INTO the bonnet rather than sitting proud of the bonnet line.
We have not taken delivery of our stagea yet but I think its got some pretty nice lines completely un modified.
IF you go fora vent just get something with a fairly low profile and get it mounted nice and tidy, the last time I Got a vent fixed up he used something like a glue to mould it onto the Bonnet.. looked the goods!
maybe ask around and get someone to do a photoshop for you?
good luck matey!
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3018276
Remember vents cannot face backwards either, it is not legal. Always make sure if you install vents that they face forwards.
I believe this is in case the engine kerplodes, and oil sprays everywhere it won't shoot straight onto the windscreen and blind the driver.
That may be a myth, but you still can't have rearward facing vents.
https://www.sau.com.au/forums/topic/162182-bonnet-venting/#findComment-3019698
    • Yes. It's either "2 wires", or 1 wire, depending on how you look at it. It is the connection that ties the battery -ve to both the chassis and the engine. Every electron that goes in or out of the battery goes through those 2 small spots (on the inner guard and on the engine block). If those are not clean and tight, then shit starts to suffer. Yeah, but measure it again cold in the morning, after it has had hours to rest. You can't usefully test the charge state of a battery immediately after it has been running because the alternator puts a surface charge onto the plates that takes a while to soak in and balance out. It will always read higher, and potentially look properly healthy, when fresh off of charge. But hours later it can look a lot less healthy. It's also worth measuring the battery voltage while cranking, although this can be difficult with a typical DMM because the screem update rate is so slow on most of them. An analogue voltmeter is actually a better tool for that. If the voltage drops too far while cranking, it is a sign of a poor battery. Although I don't think we're necessarily looking for a weak battery here - just wanting to exclude it.
    • https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.  Discounted tickets 20% off for their various tickets until the 3rd of Feb Monday. Drags, show and shine etc.  I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.  I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.  https://gtrfestival.com.au
    • Does have series 2 airbag steering wheel and passenger side airbag also.
    • Do I have a series 2 or has someone spent money to have a series 1/1.5 look like a series 2? Everything I have read says the series 2 came out in 1996. I have a car manufactured in December 1995. The exterior, engine and interior are all series 2 other than the dash facia is series 1. Paint code is also kr4 that I believe is only available on a series 2. I have a VX Vehicle History Report and it says Grade: GTS25T TYPE M2 Manufacture date: 1995-12 Make: NISSAN Model: SKYLINE Body: E-ECR33 Grade: GTS25T TYPE M2 Engine: RB25DET Drive: 2WD Transmission: F5
    • I went to Repco to get them to test the battery using their tester (not a volt meter), alternator shows 14.3v when running, and when the car was off after the it was on full load I think it was 12.6v but the guy said it was all good. Terminals are all clean, no corrosion. Though I coulda sworn when I tightened up my alternator belt the car idles a bit higher and the steering wheel shakes a bit until it's warmed up. I wanted to confirm for the earth cable/s, are you referring to the 2 wires that are bolted onto the frame rail under the battery? I might be overthinking this a bit.
