The alarm on my car started playing up the other day out of the blue...
When I arm the alarm now, it leaves the doors unlocked, so they need to be locked manually with the key...obviously if you open the door the alarm sets off, so its all working fine, other than the fact that it won't lock the doors upon arming...
anyone got any ideas as to what the problem is?
Easy fix?
cheers
https://www.sau.com.au/forums/topic/162185-sudden-alarm-issues/
Pull the trim off and check if when you arm the car that the door locking motor is working. If not, pull it out (takes about 30 sec to do), get a replacement from any car audio / security shop and replace.
Nah this sounds exactly what happened to me a while back. Keys would lock doors fine but when I used the remote sometimes it did, sometimes it didn't. Replaced motor and all was well.
The central locking motor I'm talking looks like the pictured below. (just make sure you get the one with the correct number of wires, they usually come in 2/5 wire versions).
Mine had this issue... the motors were weak.
The mounting position of the motors was not the best and it caused the motor to be over extended and eventually ineffective.. The key overrides the motor along the orignal clips hence why you can lock it with a key.
New motors are about $20 from memory... make sure it is mounted correctly too!
Ok...so I found I had one of those motors left over (they use the same 1 for boot release apparently but my installer said he didn't want to use it for that as it would fail regularly)
So I took off the door trim...I didn't even find 1 of the motors pictured above....all that was in the door looked to be factory stuff...So I basically stood there looking at stuff...poked around etc...decided I had no idea what I was doing and gave up....plugged the window control switch etc back in, armed the alarm, and bam...the doors lock now....So I fixed something...I just have no idea what exactly :(
If the motor was weak, and the rods were catching on your doortrim or something, then that would stop it from working.
To explain further on what the other guys were saying.. if you lock the drivers side door, you're overriding the motor for that door, but the passenger door gets the signal to lock/unlock when the drivers one is locked/unlocked... even if done manually.
Same way that if you lock the drivers door from the inside, the passengers side will lock automatically.
you have a S2 correct that would mean you had hte keyless option. if so tey would have used the OE actuator. I would backtrack where it was tied in and check for a loose connection. if you cnat win go see keith and get him to sort it out.
Yep, series 2...and the key it came with had keyless entry on it...Since installing the alarm I've just been using the nismo key, and the remote to open doors obviously...
I played around with a few wires in there, and it seemed to work....then died shortly after.
Just a suspicion/thought, the passenger door lock button on the drivers side window controls, I remember when the installer did the alarm, that button no longer locked/unlocked the passenger door anymore....now that the remote is failing to lock/unlock the doors, that button is working again....
When I pulled the trim off, I obviously had to disconnect the plug that controls that button and the wipers etc...The doors didn't lock from the remote until I reconnected that plug...Is there a chance its got something to do with that? If I was to cut the wire that controls that door lock button, any chance that would solve the issue?
Yeah I think i'm going to have to do the same. Weird mine was working fine until I tried locking doors while the timer was still running. Doors unlock by remote just don't lock. Sounds like we got the same problem, I'll let you know whats up with mine when I get it sorted...
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
