Hey mates,
I have heard that using the labtop and the special software to program and power fc is much better that using the commander. Is this true?
And what could be the difference?
I really want the best but cant find anybody with the software in my area.. so is the commander enough?
need your help guys
Is it true. Yes.
Differences are threefold.
1. You can see all of the maps in one go & changing between them is easier.
2. You can access more functionality by using the laptop, ie there is stuff you can;t get to using the hand controller.
3. You can do proper data logging using a laptop.
Is the hand controller sufficient to map your ecu. In short, yes.
There are a few differences.
on the software you can run a map trace and do a power run which will highlight exactly where on the map it went too and it can also highlight different colours for knock etc so that way you know exactly where you need to change the values (while it is still highlighted) and it makes tuning much much easier.
You can set values that are not available through the H/C like the VCT and locking the computer...
I have tuned a few power fc's with the hand controller and its hard. you have to run a map trace then do the power run then try and remember what part of the map it went to then you have to go back back then go into the map move to the area's and change the values which can take ages... much more time consuming. after a while you develop easy ways to tune with the hand controller but nothing is better then using the software. When the software was first available to me i did not like it very much but now i have tuned many with the software and will only use the h/c if i have to.
it is chalk and cheese, a pfc tune (complete tune) with pfc software can save you half the total time a basic tune with the hand controller would take.
99.5% of the hand controller tunes i inherit from workshops have holes all the way through them... it is virtually impossible to have holes in a software edited pfc as the whole map is on the screen at each instant.
  Quote
  Quote
I find the exact same thing!
Usually a very breif look over the map and you can see where the previous tunner has missed and line it up with the owners drivability complaint!
Something cheap and decent, and is supported by both emanage ultimate and PFC (both have literature to make intergration with fc logit simple) the ultimate has the innovate as a drop down menu in the software so it is auto set.
http://www.innovatemotorsports.com/products/lm1.php
http://www.innovatemotorsports.com/resourc...fc_tutorial.php integration information for FC-datalogit
http://www.plxdevices.com/products_widebandO2.htm
Tuning information
http://www.innovatemotorsports.com/resources/Stan2.php i have not read it so if its crap lemme know and i will remove :happy:
Edited by URAS
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
