thought it would be good to hear what dodgy stuff ppl have done to there cars...
i have on previous cars cut springs... used speaker wire to wire up stuff (driving lights/guages)......used gaffa tape on rust and painted over it (old Bomb)
  • Replies 133
I ran into a street sign in my Hyundai and held the left head light, front bumper and left front quarter panel on with cable ties, then proceeded to sell the car in this condition for $7,000. Actually felt bad about this for a while :X
Dodgy things I've done to my car?? what about the dodgy things it doing to me?? - Lately I turn up the volume on my stereo - and the airconditioning fan comes on WTF!
But in the past .....
I've heald part of my wing together with racing tape. I've cabled tied my intercooler on. Actually most mods were held on my previous car with cable ties or racing tape.
lol where do i start!!
got race tape holding my front bar together cause its scraps on every bump n has cracked it, used electicl tape around my radiator pipe cause theres a hole, so many other things but cant tell
haha yeh sometimes my windscreen wipers like to go on themselves and dont like to be turned off. have looked like a complete tool a times driving around in 30deg+ days with my wipers going nuts..
The fuel pump broke on one of the work trucks at my dads farm , so rather than walk home we found a lamb bottle these types of bottles have really long hoses to put into the lambs guts when they wont drink , this hose went into the carbretter drained abit of fuel than used gravity as the fuel pump by holding the bottle out the drivers window
I knew this fellow a few years ago to fix rust on his 4x4 he just cut it out then riveted a new piece of metal over it, a cop goes to him one night
(cop) "u can`t do that"
(bogan) "why not they do it on aeroplanes"
- Used a length of rope to remount cooler... for 5 days
- Duct taped the drivers side of the front bar after a tussle with a gutter
- Used double sided tape to mount number plates
- Cable tied pod together
- Drove around with four completely different tyres for a month
... and probably more
Painted a mates old Mazda 323 banana yellow, with housepaint, it was a good idea after drinking a lot one summer. Didn't bother masking much of it up and did the edges of anything that needed to be clear with a paintbrush... it looked dodgy then, got even worse when it got new shoes which where some huge 16" knobby rally tyres and alloy rims (they got painted yellow too) and about a 2" lift with patented MK guard flaring with a 10lb sledge as a dolly and a big f-ck off rubber mallet.
Then it was proper dodgy.
was on the way back from qld and when i got to coffs one of the rocker clips that hold the rocker into place the bolt stripped off and the only thing i could do was wrap electrical tape around the bolt and screw it back it.
It lasted months lol
cable ties are the way of life in the car scene
haha!
cable tie pod to keep it stable,
cable tie the front side & rear kit on cause i didnt have any screws,nuts or bolts..
tied the bonnet down with a piece of string coz latch was fooked lol
a friend of mine had an old hilux (paddock basher) the passenger door swung open while driving and it snapped off of the body wear the hinges are attached, due to rust!..... we welded the thing on and it lasted another couple of years!
i have seen front bars that have cracked and had heaps of cable ties put in it to hold it together.
a few cars back i had a heap of hcips on the front bar and i was going to sell it so i got a can of touchup paint and just sprayed over the top of it without rubbing it back... or cleaning the bugs off. looked great afterwards.
    • Dose is unaware just how much fun 145-150kw would be in a 2.5L NC MX5. It would be one of the most fun things to drive to ever grace SAU.
    • Same thought crossed my mind ~ depends on how one connotes 'stalling'...ie; gets a rough/stumbling idle as it get warm until it stalls... or... idles ok and simply falls-over when it gets to temp... ...you can test the whole circuit with a couple of resistors ...unplug coolant temp sensor, bridge terminals with a 2K7 resistor (ECU will do cold start), or with engine warm bridge with a 330R resistor (ECU will consider engine to be at normal operating temp)...it's a quick way to check wiring integrity/ECU response when you don't have a multimeter handy ...
    • They also make them with the motor mounted on the side
    • Just be warned that that turbo will not be a direct re-fit to the car. The exhaust housing is, of course, in the same place. It has to be - it's bolted to the exhaust manifold. So the dump will fit up. But the centre housing is not as long, so the comp housing will move backwards. This will affect both the turbo inlet and the outlet. There is fab work that needs to be done. Yes. it has one, it should have one. Paper gasket.
    • I only recently purchased the vehicle, it came with the flex setup but the current tune is e85 only, which is why im wanting to get the tune redone to enable a mixture.  First i need to get the exhaust redone tho. I was thinking of getting a varex muffler but it sems they dont fit well in the 33 (hang low because of the valve mechanism which sticks out on top) and generally dont sound good. So that leaves me with redoing the entire exhaust (more resonators and mufflers) so its not a menace when i come and go from home, and then have the aes dump valve somewhere along the line to really open it up. I was thinking of having it before the cat but after seeing how insanely loud it will be (on a vl turbo) im thinking of putting it more towards the rear of the car, after one of the resonators.
