i did loads of dodgy shit to my VN, it was my first car.
-one of the front seat mounts broke so i had a vacuum cleaner wedged behind the seat to stop me from swinging back.
-the front bar was held on by cable ties.
-i ripped the air filter out completely and put a stocking over the pipe. better performanz y0.
-the muffler was rusted so i grinded it off and didnt replace it. i also drilled a hole through the cat.
-i had a decent system in the car.. but couldnt afford a box for my sub.. so i put it in a bucket and used sikaflex to seal it.
-i removed the rear springs and cut the front ones.
  • Replies 133
there are plenty of VNs in town that are sitting on bump stops.
i've seen a xd falcon with a eb GT front bar on it. and a vh commodore with a vr front bar on it.
i have tape around the coil packs, zip ties hold my inter cooler on and my front bar. I had a rock thrown through my front windscreen and taped it up with hundred mile an hour tape. the holes in the bot lid from were the spoiler was has tope over them
commodores were meant for this kind of treatment i think. i went through 2 motors and a gearbox. i was driving it around for a few months with a failed main bearing on my 2nd motor till i sold it to a wrecker for $400.
its a huge piss off though. i spent around $5000 fixing the thing.
I've painted a car with house paint once. Looked great. Preparation consisted of one of those green scourers.
The dodgiest thing done to the Skyline is no soldering, just electrical tape on any wiring I've done.
This one wins hands down! Joe you have balls the size of Jupiter!!!
Oh man thats Gold!! :rofl:
Ive done a couple - first car was a suzuki swift - owned it for 3 years and only ever serviced it twice and it still went
- chopped the gearstick with a hacksaw to have a short shifter
- drove around with the air filter cover off - wicked induction noise yo
once had a corona wagon, only car i ever smoked in, never cleaned, kicked allot. the roof had been filled with chiprock and plaster as the metal had rusted away. chucked some sheet metal over the top an brazed the sheet on from the bottom first ofcoarse then chip-rock + plaster with housepaint finish.
got a hole in the rocker cover so distinct lack of compresion so welded on some sheet metal then proceded to weld the cover to the motor. all compression issues fixed. had a leak in the exhuast which made the most anooying whistling sound so pulled of the rear muffler, found something of some other econo box @ reckers that matched ish to the brackets and just stuck it in there. car came for free, sold for $400 to reckers. did tell him most of hte car was not metal and he still offered me that much for the shitter
dodgiest thing ever done to line
took of S2 wing and added 33 r wing with rear brake light.
never skimp on anything when it comes to the beasty, solder and even bloody heat shrinks etc. love my common whore of a 33 I DO!
i crashed a toyota coroner into a tree trying to be a rally car driver once
it bent a rod in the steering so i brought the rod into school and got the metal works teacher to bend it bak. then i put i back on the car n drove around. the car was so f**kin dangerous but i still drove it around the place :rofl:
umm.....
used newspaper and chicken wire to fix rust spots(bogged over of course)
bought $500 cars, washed them properly, tuned them and gave em some new carpet and sold them for $2000
:rofl:
amazing what people will buy
could you still turn right?
oh man, had a mate dry an rip heli's in that crap box an bent the rod on the left side, old shitty steel, it was on DIRT! paddick bask on the grans farm FTW!
yea most expensive fix on the car ever... $120 for a newy cuase i actualy was driving it an sterring + braking on anything im using on the street needs them 2.
though my ol 72 sl tor'y couldnt really make that claim an it was taken care of... 72 steel shiz, not bad going in a straight line, upg to disks all around to.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
