took apart the carbi in a crapbox that i've been using.
mate lost a circlip for a throttle linkage. i lost whatever holds the other throttle linkage
so i just got some paper clips, bent them around to replace clips :cheers:
still running fine ha
one day it'll either not accelerate or jam open ;)
  • Replies 133
a guy i know has a gemini and he knows when to top up the oil by hom long the oil light stays on for when he stops at an intersection. when it stays on for longer than a certain number of seconds it needs topping up.
lol thats a good one. I have dodged up so much on my daily driver. The throttle body on the carby is so worn out that it wouldn't close properly and always idled high depending on if the butter fly jammed or not. So just added an extra return spring onto it to help pull it back close properly.
I when i need new brake pads on the rear drums i just look thru a box of spares that i have and find some old ones that have good meat left on them. seems to wear the leading pad out faster so i just get a whole bunch of rear pads that i find and put them on. The leading and trailing pad seem to be the same so interchangable. saves few $$.
When i bust a CV boot cover thats no sweet. I just get some plasitc bag and wrap that around it and duct tape that sh!t on. last for longer than u would think.
Radiator is always getting holes in it. but i just dodge up that with some metal mend putty. It now seems to have more putty on it than metal lol.
The structural support for the sills under the car are a little rusted out and make it hard to lift the car there :). Had to get a RWC for the car so just bogged the rusted out area up and shapped it to look like the original chassis. then painted it with body deadner and when dry i just mixed up some nice mud and splatted that all around under the car to hide all. Didn't bother washing it for the assesors.
The rubber steering joinner on the steering shaft wouldnt pass RWC cos it had some small cracking in it, so i just rubbed grease into the crack to hide it and they didnt notice.
Reverse light switch in gear box buggered up so i wired the factory wiring to a switch in the car now so i have to flick a switch now to turn reverse lights on.
Brake calipers where shaking around all the time on the pads and rotor because the securing pins where worn. So just wrapped the pins with aluminum flashing (stuff u use on a house) and shoved it back in.
Hmm did a few other things. will add them as i remember.
The structural support for the sills under the car are a little rusted out and make it hard to lift the car there ;). Had to get a RWC for the car so just bogged the rusted out area up and shapped it to look like the original chassis. then painted it with body deadner and when dry i just mixed up some nice mud and splatted that all around under the car to hide all. Didn't bother washing it for the assesors.
does this guy win dodgyness of the year award? i think so!
this thread is a classic
Got defected in my old nissan NXR for height of 70 mm. got it to 110mm by jacking it up and jamming about 20 blocks of rubber in between each spring coil and had no travel at all. too scared to drive it and was for sale anyway. sold it the next week and the lady drove it home from my house in Newcastle to VICTORIA with 80 rubber blocks jammed in the springs. couldnt stop laughing. hope she made it home ok
The structural support for the sills under the car are a little rusted out and make it hard to lift the car there :closedeyes:. Had to get a RWC for the car so just bogged the rusted out area up and shapped it to look like the original chassis. then painted it with body deadner and when dry i just mixed up some nice mud and splatted that all around under the car to hide all. Didn't bother washing it for the assesors.
Thanks guys. I do try. lol.
We all know who the man is around here!!
Your a legend love it!! I thought I was dodgey with my corolla but you by far take the cake!! much respect!
tie rod ends held on by 3 thread turns for a 8 hour track day
well, the minimum requirements for fitting is 2 thread turns - and that is for pressure fittings
as longs as its lock-tited on alright....
another dodgy thing iv done, thought id do a lil bush mechanic short shifter which consisted of a hack saw, cut it nice and short then found a small shift knob,
it was too big for the shifter so i got a bolt and super glued it inside the shifter and then put the threaded end of the long bolt into the hole in the shifter, threads on the bolt were too skinny so i just filled up the shifter hole with super glue lol, its nice and STUCK in there now
god knows how im gonna get it off :P
me and my mates have done:
- power right mirror works only when a cable tie is used to adjust angle of bunch of cables going through grommet.
- driving around for 4 months without rear seats
- using bandaids to hide rust spots
- running 4 speakers from a 2 channel amp, 2 speakers eventuallly blew
- attaching side skirts and rear pods to hide accident damage and rust, then sold the car
- driving with no transmission oil, no service ever, it lasted for a year and many burnouts. Got $160 scrap metal, cost $200.
    • I have done smoke test and can’t see any leak on high or low side.   checked pump and fluid can flow through. Removed the high pressure from steering and did smoke test and same on low side, no leak.   puzzled. Thinking why if it was all ok it suddenly went as car was off road for a year. Don’t want to disassemble pump yet as i can see fluid / air( compressor) can flow through with no issues
    • Which manifold mate? Meanwhile......Mark is wondering how bonnet vents would look on the NC 🤣
    • Actually,  just remembered there should be info in the threads (somewhere) about swapping to a manual steering rack and deleting power steering all together.
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
