i did loads of dodgy shit to my VN, it was my first car.
-one of the front seat mounts broke so i had a vacuum cleaner wedged behind the seat to stop me from swinging back.
-the front bar was held on by cable ties.
-i ripped the air filter out completely and put a stocking over the pipe. better performanz y0.
-the muffler was rusted so i grinded it off and didnt replace it. i also drilled a hole through the cat.
-i had a decent system in the car.. but couldnt afford a box for my sub.. so i put it in a bucket and used sikaflex to seal it.
-i removed the rear springs and cut the front ones.
  • Replies 133
there are plenty of VNs in town that are sitting on bump stops.
i've seen a xd falcon with a eb GT front bar on it. and a vh commodore with a vr front bar on it.
i have tape around the coil packs, zip ties hold my inter cooler on and my front bar. I had a rock thrown through my front windscreen and taped it up with hundred mile an hour tape. the holes in the bot lid from were the spoiler was has tope over them
commodores were meant for this kind of treatment i think. i went through 2 motors and a gearbox. i was driving it around for a few months with a failed main bearing on my 2nd motor till i sold it to a wrecker for $400.
its a huge piss off though. i spent around $5000 fixing the thing.
I've painted a car with house paint once. Looked great. Preparation consisted of one of those green scourers.
The dodgiest thing done to the Skyline is no soldering, just electrical tape on any wiring I've done.
This one wins hands down! Joe you have balls the size of Jupiter!!!
Oh man thats Gold!! :rofl:
Ive done a couple - first car was a suzuki swift - owned it for 3 years and only ever serviced it twice and it still went
- chopped the gearstick with a hacksaw to have a short shifter
- drove around with the air filter cover off - wicked induction noise yo
once had a corona wagon, only car i ever smoked in, never cleaned, kicked allot. the roof had been filled with chiprock and plaster as the metal had rusted away. chucked some sheet metal over the top an brazed the sheet on from the bottom first ofcoarse then chip-rock + plaster with housepaint finish.
got a hole in the rocker cover so distinct lack of compresion so welded on some sheet metal then proceded to weld the cover to the motor. all compression issues fixed. had a leak in the exhuast which made the most anooying whistling sound so pulled of the rear muffler, found something of some other econo box @ reckers that matched ish to the brackets and just stuck it in there. car came for free, sold for $400 to reckers. did tell him most of hte car was not metal and he still offered me that much for the shitter
dodgiest thing ever done to line
took of S2 wing and added 33 r wing with rear brake light.
never skimp on anything when it comes to the beasty, solder and even bloody heat shrinks etc. love my common whore of a 33 I DO!
i crashed a toyota coroner into a tree trying to be a rally car driver once
it bent a rod in the steering so i brought the rod into school and got the metal works teacher to bend it bak. then i put i back on the car n drove around. the car was so f**kin dangerous but i still drove it around the place :rofl:
umm.....
used newspaper and chicken wire to fix rust spots(bogged over of course)
bought $500 cars, washed them properly, tuned them and gave em some new carpet and sold them for $2000
:rofl:
amazing what people will buy
could you still turn right?
oh man, had a mate dry an rip heli's in that crap box an bent the rod on the left side, old shitty steel, it was on DIRT! paddick bask on the grans farm FTW!
yea most expensive fix on the car ever... $120 for a newy cuase i actualy was driving it an sterring + braking on anything im using on the street needs them 2.
though my ol 72 sl tor'y couldnt really make that claim an it was taken care of... 72 steel shiz, not bad going in a straight line, upg to disks all around to.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
