took apart the carbi in a crapbox that i've been using.
mate lost a circlip for a throttle linkage. i lost whatever holds the other throttle linkage
so i just got some paper clips, bent them around to replace clips :cheers:
still running fine ha
one day it'll either not accelerate or jam open ;)
  • Replies 133
a guy i know has a gemini and he knows when to top up the oil by hom long the oil light stays on for when he stops at an intersection. when it stays on for longer than a certain number of seconds it needs topping up.
lol thats a good one. I have dodged up so much on my daily driver. The throttle body on the carby is so worn out that it wouldn't close properly and always idled high depending on if the butter fly jammed or not. So just added an extra return spring onto it to help pull it back close properly.
I when i need new brake pads on the rear drums i just look thru a box of spares that i have and find some old ones that have good meat left on them. seems to wear the leading pad out faster so i just get a whole bunch of rear pads that i find and put them on. The leading and trailing pad seem to be the same so interchangable. saves few $$.
When i bust a CV boot cover thats no sweet. I just get some plasitc bag and wrap that around it and duct tape that sh!t on. last for longer than u would think.
Radiator is always getting holes in it. but i just dodge up that with some metal mend putty. It now seems to have more putty on it than metal lol.
The structural support for the sills under the car are a little rusted out and make it hard to lift the car there :). Had to get a RWC for the car so just bogged the rusted out area up and shapped it to look like the original chassis. then painted it with body deadner and when dry i just mixed up some nice mud and splatted that all around under the car to hide all. Didn't bother washing it for the assesors.
The rubber steering joinner on the steering shaft wouldnt pass RWC cos it had some small cracking in it, so i just rubbed grease into the crack to hide it and they didnt notice.
Reverse light switch in gear box buggered up so i wired the factory wiring to a switch in the car now so i have to flick a switch now to turn reverse lights on.
Brake calipers where shaking around all the time on the pads and rotor because the securing pins where worn. So just wrapped the pins with aluminum flashing (stuff u use on a house) and shoved it back in.
Hmm did a few other things. will add them as i remember.
The structural support for the sills under the car are a little rusted out and make it hard to lift the car there ;). Had to get a RWC for the car so just bogged the rusted out area up and shapped it to look like the original chassis. then painted it with body deadner and when dry i just mixed up some nice mud and splatted that all around under the car to hide all. Didn't bother washing it for the assesors.
does this guy win dodgyness of the year award? i think so!
this thread is a classic
Got defected in my old nissan NXR for height of 70 mm. got it to 110mm by jacking it up and jamming about 20 blocks of rubber in between each spring coil and had no travel at all. too scared to drive it and was for sale anyway. sold it the next week and the lady drove it home from my house in Newcastle to VICTORIA with 80 rubber blocks jammed in the springs. couldnt stop laughing. hope she made it home ok
The structural support for the sills under the car are a little rusted out and make it hard to lift the car there :closedeyes:. Had to get a RWC for the car so just bogged the rusted out area up and shapped it to look like the original chassis. then painted it with body deadner and when dry i just mixed up some nice mud and splatted that all around under the car to hide all. Didn't bother washing it for the assesors.
Thanks guys. I do try. lol.
We all know who the man is around here!!
Your a legend love it!! I thought I was dodgey with my corolla but you by far take the cake!! much respect!
tie rod ends held on by 3 thread turns for a 8 hour track day
well, the minimum requirements for fitting is 2 thread turns - and that is for pressure fittings
as longs as its lock-tited on alright....
another dodgy thing iv done, thought id do a lil bush mechanic short shifter which consisted of a hack saw, cut it nice and short then found a small shift knob,
it was too big for the shifter so i got a bolt and super glued it inside the shifter and then put the threaded end of the long bolt into the hole in the shifter, threads on the bolt were too skinny so i just filled up the shifter hole with super glue lol, its nice and STUCK in there now
god knows how im gonna get it off :P
me and my mates have done:
- power right mirror works only when a cable tie is used to adjust angle of bunch of cables going through grommet.
- driving around for 4 months without rear seats
- using bandaids to hide rust spots
- running 4 speakers from a 2 channel amp, 2 speakers eventuallly blew
- attaching side skirts and rear pods to hide accident damage and rust, then sold the car
- driving with no transmission oil, no service ever, it lasted for a year and many burnouts. Got $160 scrap metal, cost $200.
    • Speaking of diverting threads, my second ever NISMO purchase…. I think they look pretty classy and just wanted to share 😅   PS: 1st was the oil drain plug 😂
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
