  • Replies 133
a while back i ass ended a holden with a tow bar in my old 626 which dinted in the front-middle of my car in about a foot and bent my radiator nearly right angles. so we drove her to the nearest stable looking tree and tied her to it, wacked it in reverse and wallah. threw the bumper in the boot, disconnect the rad fan.
$30 for a bumper from the wreckers and 20 000km later and still goin strong.
not that dodgy but i got the new grill just hours before leaving for autosalon. since i didn't have time to make brackets and look for new screws the bonnet is holding the grill in place. chances are ill probably leave it like this.
was going on a cruise, suddenly on the way i hit some animal and my front bar was literally 'falling apart bit by bit'. had no choice but to use something to stick the main joints together. too far away to convenience store to buy duct stape or cable-ties etc, so me and my mate took turns chewing up 2 packets of wigleys chewing gum that we had bought days ago, we then used that to stick back the main joints (of course some screws held it together too) but it worked. funny enough, after a while the chewing gum gets really hard and actually holds the car together well.
and for those wondering, 'no' - i don't still have gum on my car. ha ha ah
funny thread and posts.
Went to a mates house in woodridge in the afternoon in my sisters car, went to come home at night and notice the low beams in the car had blown, one of them was already blown, had to get back to the goldie for work, so i put tin foil under the headlight covers and drove home with the lights on high beam with just a small section of light shining thru. Also the usual cable ties and ducktape on front bar, pod filter etc
  • 4 weeks later...
another dodgy moment i had a flat and the spare wheel i had was not the right off set and was hitting the front brake caliper....... i had 4 washers handy which i used as a spacer.......the steering was wobbling bad and felt quite dodgy haha
On my old civic I needed a longer intake pipe and adaptor for the pod so I cut a 600ml coke bottle to size and that fit perfectly into the stock intake pipe and the pod. Held in place perfectly and also gave awesome deep intake sound. After that my friends started to call my house ‘ghetto mods performance centre’. Lol.
After the 4age (legendary corolla engine) spat a rod, I bought a 7afe (different head, taller block, same bore) for $200 from a wreckers. ripped out the 4age and box, split them joined the 7afe and box and put them back in. Fart arsed around trying to get the eletrics hooked up, gave up, ripped the 7afe head off put the 4age head on, despite the fact that one of the cam bearings was totally rooted, oh yeah, re-used the head bolts LOL, that was 40,000 Ks ago...still going strong, touch wood. Its really funny most of the mechanics I talked to were like "It can't be done" "That's a waste of a head gasket" LOL
Edited by machg
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
