its a CA18det, the coolant disappears quick, idles rough, timings out and bubbles in the radiator. Are these the symtoms of head gasket or are there anything else that i could test to see if the gasket is gone.
thanks guys
Now if the coolant is dissapearing quick, check for leaks.. Run the car go for a cruise come home sit around and watch..
Now i dont know ca18's but have you change the radiator and does it have a Pressurised cap.. Alot of people notice there coolant bubbling around when they shut the car off due to the pressure from the radiator pressing down.. and also the coolant bottle having a pressured cap pressing down also..
Symptoms of a headgasket are milky coolant.
Guest 40th-edition
that sounds like classic head gasked or even cracked head 4 sure.... you can pressure test it and then leave sit with pressure over night or couple of hours then crack and see if its hard to start or even hydrolic locks..
even a TK tester would do it but i would say head 4 sure!
thanks guys
ca18 are prone to blowing headgaskets
check the lh side of the block (where the power steering pump is) check for coolant leaking down the block
but usually the blow between cylinder and water jacket so u will rarely see coolant mixed in with the oil on a ca18
btw u will get a better responce if u go to www.nissansilvia.com as there are alot of ca18 freaks on this site
the whole engine is flooded with leaks, i can't believe the last owner. since owning the car i realised the car has had a hard and neglected life :P but thanks for the advice boot_it
Welcome to the world of CA's, does there appear to be a frothy substance in the radiator only when its on? more than likely the head gasket is gone, CA's are bordering on 20 years old. The poor 4 cylinder is on its lasts legs.
Most 180's or jap cars for that matter have had a hard life, its just a matter of getting one that wasnt treated as bad as others.
Cheers, Semo
Cheers, Semo
maybe i should send it to the grave and replace it with a lil younger sr20det :D i got this car cheap, and being an automatic i assumed it was ever owned by decent poeple................... how wrong was i. :)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
