Rb26 In 2000 Model Jeep...edit. Now In R32 Gtr
  • Replies 107
but its not a great looking bank balance...some more shots
You only live once hehe just try not to think of the money.
What sorta power is this beautiful thing gona produce ?
Same as yours
Ahhh...looked familiar :sorcerer:
What's happening on the induction side of things - is that a single throttle body manifold I spy?
Are we also going to MAP load sensors sir?
Hypertune Plenum and CNC'd runners and single Hypertune throttle body with 97mm butterfly.
No MAP sensors...new Z32 AFM's actually...it will work.
sooo would love to know what that set you back mate.
pm FTW!
here's a list...you work it out
BLOCK...sonic test, chemically clean, torque plate bore and hone, mill block, drill and tap for 12mm main studs
CRANK...new Nissan crankshaft, drill crankshaft to remove alloy oil plugs and tap for screw type
ENGINE...JUN pistons pins and rings, JUN conrods, JUN oil pump, JUN main studs, ARP head studs, Tomei cam cap studs, new Nissan oil squirters and bolts, TRUST "drag" head gasket, JUN metal inlet exhaust gasket kit, Nissan gasket set, Hi Octane 9 litre baffled sump.
HEAD...machine for cam lobe clearance, remove oil plugs thread and grub screw, full race port and polish, modify combustion chambers and high polish, instal bronze guides, cut 3 angle valve seats, lap valves and set heights, JUN camshafts, JUN titanium retainers, JUN valve springs, Tomei lifter buckets, Nitto stainless steel valves (1mm oversize), Mines cam cover baffle kit.
EXTRAS...full engine balance and assembly, fit front Cusco 1.5 way diff to new sump, port match all manifolds turbo's and plenum, TRUST twin entry "drag" intercooler, Hypertune race plenum, Hypertune 100mm single throttle body, NPC twin plate race clutch.
I already had the turbo's (HKS GT-RS) manifolds and dumps which have been ceramic coated from our last engine. These have only done two passes and are as good as new.
As you can see nothing has been left to chance.
 Share
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
    • Here's the torque curves from the car I ramped boost up later in the rpm to allow a slightly wider useful power curve - the power curve is a bit weird shaped also thanks to the TVIS (or whatever they call it with the 4EFTE in this Starlet) which changes the volume of the intake manifold throughout the rpm range, but you can see that the green power curve actually holds later on with the extra boost... but looks almost more like the kind of thing you'd expect from a cam or exhaust change
