Congrats to Steve Glenney who finished 2nd to Jim Richards in Targa Tasmania. He Was in a R33 GTR which i believe is prepared by Tillbrooks here in SA. A good effort as i dont think any one can really match Richards ability and equipment.
Quote From Targa website:
Porsche driver Jim Richards won the Targa Tasmania tarmac rally Modern Competition for the seventh time after turning back a strong challenge from South Australia's Steve Glenney in today's fifth and final leg.
Richards and Tasmanian navigator Barry Oliver won the 12th annual Targa event in a turbo Porsche 911 with the lowest penalty time of 22-mins 30-secs. They finished 1-min 10-secs clear of second-placed Glenney and his navigator Clayton Lang, also from South Australia, in a Nissan Skyline GTR.
https://www.sau.com.au/forums/topic/16224-gtr-2nd-in-targa-tas/
nice.. i heard of an R34 GTR N1 being specc'ed out for rallying that was from tassie.. not sure whether it was in this Targa .. but i think it might been in the next one.
Apaprently they got a top 10 finish last year in an EVO but they needed more power so they went the GTR.
i would say not even a porsche 911 turbo would be able to beat the combo of Richards and GTR
oh and gordy, that R34 GTR N1 was staying around my area in Hampton. Saw it down Hampton st a few times... then saw it parked outside a house, with like the names on the rear side windows and all the stickers. Look awesome!! too bad i didn't have a digi cam with me :) Up close tho, it looks friggen mean.
The stickers are different to the ones i saw in the pic above, but i doubt that the chances of there being 2 White, R34 GTR N1's with full rally spec cosmetics and mods in Oz. And i'm pretty sure had Jason White on the side window, but really can't remember.
I want to see Jim Richards in a R34 GTR N1 next time.. now that would be the coolest :)
Ok here we go
R33 genuine N1's
806Steve Glenney SA1995 Nissan Skyline GT-R V-Spec N1 what an absolute gun !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
914 Jeff Keyte, TAS 1998 Nissan Skyline GT-R V-Spec N1 Mines
R34 genuine N1's
934 John White, TAS 2001 Nissan Skyline GT-R V-Spec II N1
941 Peter Moore, 2002 Nissan Skyline GT-R V-Spec II N1
942 George Nittis, 2000 Nissan Skyline GT-R V-Spec II N1
were also R32 and R33 GTR N1 "replicas"
check www.targa.org.au for more information
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
