Borrowed from Jay95's Leather Handbrake Boot installation instructions.....
What we need to do is take the centre console (the part between the two front seats)out of the car.
With the plastic surround that goes around the gearstick still off, undo the two screws that were under the plastic surround that you just took off.
Then open up the centre console bit and undo the two screws inside the compartment. If your car has duel airbags, then these two screws will be on the outside of the console, on either side of it. You can get to them if you move your seats all the way forward and tilt them forward too.
Once the screws are out, unbutton the to studs that are on the factory handbrake boot, then the whole centre console bit can be lifted up and forward to get it out of the car. Just be careful not to scratch your stereo with the console when you take it out.
Once the console is out of the car, turn it upside down and with the help of a small flat headed screwdriver, gently prise the handbrake boot out of the console.
The factory handbrake boot has a wire frame sewn around the base of it.
Once it's out of the console, you'll need to cut the wire frame out of the factory boot, and sew it into the base of the new boot. Just remember the way the frame is sitting in the factory boot. I'm pretty sure the high side of the wire frame goes to the drivers side.
Once the wire frame is sewn in, pop it back into the centre console and re-install the centre console and the plastic surround around the gearstick.
Whala - all done.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
